my car died... im home and not my car... tell me wat u think.
Old Dec 10, 2003 | 09:11 PM
wizzards581's Avatar
Default my car died... im home and not my car... tell me wat u think.
well while the ignition key is turn to ON... nothing lites up... which if u turn it to ACC at alittle angle off the ON position it lites bac up.. or if u turn alittle angle to START then it lights back up... i can start it and hold the keys towards START and the engine runs fine.. but letting it go back on to ON position then it shuts down completely. i know its the ignition inside the key somewhere.. do you guys know anything or whats its called so i can buy the piece for it? is it some kind of coil that is worn out and not being shorted to keep the power on..?
Old Dec 10, 2003 | 09:12 PM
sohcvtec1995's Avatar
Default Re: my car died... im home and not my car... tell me wat u think. (wizzards581)
its your ignition.
Old Dec 10, 2003 | 09:25 PM
Heavy Pee's Avatar
Default Re: my car died... im home and not my car... tell me wat u think. (sohcvtec1995)
yeah , it's the ignition switch
Old Dec 10, 2003 | 09:30 PM
Grimace EJ6's Avatar
Default Re: my car died... im home and not my car... tell me wat u think. (Hvy P)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hvy P &raquo;</TD></TR><TR><TD CLASS="quote">yeah , it's the ignition switch</TD></TR></TABLE>
i THINK he means the ignition lock cylinder. u can pick one up and it should come with a new set of keys. good luck
Old Dec 11, 2003 | 04:49 AM
Default Re: my car died... im home and not my car... tell me wat u think. (Grimace EJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grimace EJ6 &raquo;</TD></TR><TR><TD CLASS="quote">
i THINK he means the ignition lock cylinder. u can pick one up and it should come with a new set of keys. good luck</TD></TR></TABLE>
does it come with the doors, trunk.. etc? the key wholes....
Old Dec 11, 2003 | 06:22 AM
Ricey McRicerton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wizzards581 &raquo;</TD></TR><TR><TD CLASS="quote">
does it come with the doors, trunk.. etc? the key wholes....</TD></TR></TABLE>
I doubt it...then you would have to replace all of those locks as well. You could take out all the tumblers, but then you could open them with anything (but as long as you don't tell anyone it should be all good)
Old Dec 11, 2003 | 07:32 AM
JICB16B's Avatar
Default Re: my car died... im home and not my car... tell me wat u think. (Ricey McRicerton)
no the ignition switch comes seprate you need that not the lock cylinder
Old Dec 11, 2003 | 08:42 AM
EGh22aEG's Avatar
or you could just have two different keys i did with my older civic it wasnt a big problem
Old Dec 11, 2003 | 02:46 PM
Heavy Pee's Avatar
Default Re: my car died... im home and not my car... tell me wat u think. (EGh22aEG)
Ignition switch connects to the lock cylinder. You can unhook the ignition switch from the lock cylinder, stick a screwdriver in it ,start it, and see if it still has the same problem. I bet it will.
Old Dec 11, 2003 | 04:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hvy P &raquo;</TD></TR><TR><TD CLASS="quote">Ignition switch connects to the lock cylinder. You can unhook the ignition switch from the lock cylinder, stick a screwdriver in it ,start it, and see if it still has the same problem. I bet it will.</TD></TR></TABLE>
yes i seen GSRs that got jacked and those things fall in two pieces. which they use the screw driver to start it. so its the ignition switch which doesnt concern the key pattern is the piece i will need to change? my bro called honda and they said i need the whole thing which is roughly about 200... i dont think its a big problem jus to fix it is it?
Old Dec 11, 2003 | 05:09 PM
kingSfit's Avatar
ur starter?
Old Dec 11, 2003 | 06:14 PM
Default Re: (Bunz)
cant be the starter. i can drive my car in first gear while holding the keys angling towards the START but if i let go off to the ON then everything shuts off blank! no lights... unless its been angled towards START or ACC... cant stay in the middle of ON...
Old Dec 11, 2003 | 06:25 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">its your ignition.</TD></TR></TABLE>
si senior
Morag
May 21, 2017 10:12 AM
honda305
10
Dec 1, 2006 10:32 PM
prelude9201
Apr 12, 2005 02:15 PM
liljohnson
Aug 12, 2004 11:48 PM
deviant94ex
Feb 17, 2004 09:45 AM
