compression test results.....weird?
i did a compression test today. the numbers seem kinda high. what you guys think?
95 H23
66000 miles
completly stock
60 degress outside
engine warmed up to normal temp.
throttle at WOT during test
pulled ecu fuse
brand new tester
all spark plugs removed
results
#1 #2 #3 #4 each cylinder was test 3 times and same #'s
220 220 215 215
these #'s seem really high but at least theyre consistant. what do you guys think?
Thanks,
David
95 H23
66000 miles
completly stock
60 degress outside
pulled ecu fuse
brand new tester
results
220 220 215 215
Thanks,
David
thanks for the replies. but i dont think its carbon build up because i always use 93 octane. just got back from a 400 mile trip on sunday and when i wind out the engine it doesnt blow out any carbon. so i dunno its runnin fine ...im not worried
thanks,
David
thanks,
David
Good #'s
