The Itr's Compression is LOW...Need Help......
Old Jan 18, 2006 | 08:15 AM
DRKSol's Avatar
Default The Itr's Compression is LOW...Need Help......
We did a compression test yesterday and the results were:
cyl 1- 110
cyl 2- 110
cyl 3- 118
cyl 4- 120
Oh Yeah...Its a Boosted R...Just needed some info on what else except for rings it could be
Old Jan 18, 2006 | 08:21 AM
bdavis's Avatar
Default Re: The Itr's Compression is LOW...Need Help...... (jh)
that is low, but have you tried that tester on another vehicle with known good compression? Perhaps try another tester to confirm the accuracy of this one.
Does is smoke a lot under load???
sorry to hear that, but best of luck to you
splitime's Avatar
Those numbers aren't really scary... since they are somewhat close... did you guys test it at WOT? with all plugs out? with ecu fuse pulled? etc....
If you had like 200-100-200-200.... that i'd worry about.
Old Jan 18, 2006 | 08:23 AM
Finland's Avatar
Make sure the engine is at normal operating temperature prior to conducting the test.
76 camaro car
Apr 20, 2017 04:47 AM
MarkCayabyab
10
Oct 29, 2013 06:18 PM
SilkyJohnson
13
Feb 15, 2011 05:54 PM
Junkie
Mar 22, 2008 12:21 PM
flangemastermike
May 31, 2006 08:13 AM
