what are good vacuum sources on the IM?
Old Dec 4, 2003 | 07:27 AM
xXx Justin xXx's Avatar
Default what are good vacuum sources on the IM?
i have several things that need to be tapped. a shitty fmu, boost gauge, boost controller.
i know the FMU should go to the FPR vacuum line. and i also have my boost gauge T'd off of that as well. the the MBC goes from the wastegate actuator to the MBC, T'd in with the BOV...then to where on the IM? thanks.
and it is the middle (single arm) side of the MBC that leads to the wastegate actuator right? the side straight across from the screw goes to the vacuum source?
Old Dec 4, 2003 | 02:57 PM
anybody?
Old Dec 4, 2003 | 03:01 PM
Scammer's Avatar
my soch set up is....
boost to fpr vac line
fmu to the back lower part (where the cruise control is)
the mbc is inbetween the turbo and wg.
Old Dec 4, 2003 | 03:07 PM
TeStUdO's Avatar
Default Re: what are good vacuum sources on the IM? (SOHC Beast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC Beast &raquo;</TD></TR><TR><TD CLASS="quote">i have several things that need to be tapped. a shitty fmu, boost gauge, boost controller.
and it is the middle (single arm) side of the MBC that leads to the wastegate actuator right? the side straight across from the screw goes to the vacuum source?</TD></TR></TABLE>
Try using the brake booster vacuum as well
Old Dec 4, 2003 | 03:08 PM
redboost10's Avatar
Default Re: what are good vacuum sources on the IM? (TeStUdO)
you can use a vacuum manifold from mcmaster.com or golden eagle, just an idea
Old Dec 4, 2003 | 07:38 PM
Default Re: what are good vacuum sources on the IM? (tgh99si)
i forgot about the vacuum nipple on the back of the y8 IM. i have a d16y7... so it is just capped anyway. and i dont have a vac. nipple on the turbo.....thanks for the help guys.
CivicDude2k4
Jul 31, 2006 08:18 AM
tony n.
Jun 14, 2005 06:15 PM
Etylorcen
Jun 24, 2002 11:11 AM
ludelvr
Apr 30, 2002 12:44 PM
