Car Takes forever to start when engines cold
Old Dec 3, 2003 | 11:59 AM
devonic's Avatar
Default Car Takes forever to start when engines cold
Hey all,
i got a problem with my civic. for some reason when my engine is cold my car takes forever to start. Every morning and when i leave work when i go out it usually takes me anywhere from 3-5 mins to get it to start, and when i do the idle is so low it usually stalls a few times until i can get it to actually stays on and starts to idle. if i give it a little gas after i start it up i it sputters and i can hear the intake backfiring. now that its getting colder here in pa, its taking longer to start up. any ideas what it could be
setup - 99 dx 5 spd engine using 98dx ecu + greddy 15g turbo kit, 1 step colder ngk plugs
Old Dec 4, 2003 | 04:00 AM
devonic's Avatar
Default Re: Car Takes forever to start when engines cold (devonic)
morning crew?
also, using y8 intake mani and y7 tb
Old Dec 4, 2003 | 04:05 AM
1700anddroping's Avatar
check and see if you are getting spark and also check your fuel filter it could be really clogged.it will BE one of the things i mentioned.
Old Dec 4, 2003 | 04:27 AM
devonic's Avatar
Default Re: Car Takes forever to start when engines cold (1700anddroping)
i'll check them out, thanks
also,im using a y7 tb and a y8 im, not sure if its important but only one of my o2 sensors is in my exhaust system, the other is sitting in my engine bay(no 2nd bung on greddy kit)
Modified by devonic at 10:05 AM 12/4/2003
end005
Sep 28, 2012 03:47 AM
Ryan Lwin
Sep 8, 2012 07:41 PM
Jz6m
Jul 27, 2011 09:51 PM
my car sucks84
13
May 21, 2005 06:53 AM
devonic
16
Dec 5, 2003 05:25 AM
