Motor Install-Lots of Problems...Help Me Out!
Old Dec 2, 2003 | 05:33 AM
vtecb20coupe's Avatar
B A N N E D
Default Motor Install-Lots of Problems...Help Me Out!
ok, here's what's going on. basically rebuilt a jdm 2nd gen b16a, replaced all seals, belts, head gasket, rings, etc. the bottom end is stock and the head has a ctr intake cam. it's got the basic i/h/e and b&m fpr as well. the head was sent to the machine shop, replaced the intake valves for some itr ones and replaced the valve seals. no springs or retainers were changed though. i have not had the chance to install the skunk2 cam gears as i am waiting for them to come in so i'm using stock ones. the fpr is reading 34 psi(not sure if this is enough for the ctr cam).
i am pretty sure that the car needs a valve adjustment because it's making the noise we all know about. i'm pretty sure the timing is straight but i'm beginning to wonder if it may be off like a tooth. there is no knocking or pinging. when the car is cold and you attempt to start it, it will start but immediately cuts off. but you can start it right back up easily, no hesitation.
if you give it gas until the car warms up, it will stay on with no assistance and idle fine at 750 rpm. however, if you take it for a test drive and go into corners, the car will cut off but start back up immediately. sometimes it feels as if the throttle gets stuck in the low rpms as well but once you reach say 1500-2000 rpm, it's all good.
could the valves be staying open causing it not to feel as powerful as it should( like there's not enough compression). or what would be causing it to cut off or stall like it is? i know it's either timing, valves, or not enough fuel that's causing all my issues. any help is appreciated! thanks.
Old Dec 2, 2003 | 09:03 AM
B A N N E D
Default Re: Motor Install-Lots of Problems...Help Me Out! (vtecb20coupe)
anybody got any info for me?
Old Dec 2, 2003 | 09:09 AM
StyleTEG's Avatar
I would recheck your cam timing, since its quick and easy to do and could definetly cause some of those problems.
Old Dec 2, 2003 | 10:32 AM
B A N N E D
Default Re: Motor Install-Lots of Problems...Help Me Out! (StyleTEG)
and how would you go about just checking the cam timing? or are you referring to the timing of the whole motor, ie. distributor, crank, cams, etc?
Old Dec 2, 2003 | 11:24 AM
StyleTEG's Avatar
Using the white mark on the crank pulley, set the pistons at TDC and make sure that the cam gears are aligned at TDC as well.
If they are not, your cam timing is off.
Old Dec 2, 2003 | 01:13 PM
B A N N E D
ok, this is what i did, based upon the helms manual. set piston #1 at tdc and there are three notches on the pulley. i aligned the middle(red) notch with the notch on the timing belt cover that's to the left of the tensioner bolt. i then aligned the cam gears to tdc. everything looks fine and straight.
Old Dec 2, 2003 | 01:28 PM
mattssi's Avatar
That middle mark is about 15 degrees off of tdc, but good try! The single white mark on the pulley just to the right of those is the tdc mark! set your timing to that and you will be set! The three little marks is for setting you timing via distributor once the car is running!
Old Dec 2, 2003 | 06:27 PM
StyleTEG's Avatar
Default Re: (mattssi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">That middle mark is about 15 degrees off of tdc, but good try! The single white mark on the pulley just to the right of those is the tdc mark! set your timing to that and you will be set! The three little marks is for setting you timing via distributor once the car is running! </TD></TR></TABLE>
exactly!
Old Dec 2, 2003 | 07:20 PM
chrisCNL's Avatar
Default Re: (StyleTEG)
is there any check engine light on??? get those out of the way first...process of elemination...
Old Dec 3, 2003 | 05:15 AM
B A N N E D
Default Re: (chrisCNL)
yea, there is a check engine light which i plan to have checked out tomorrow. since it's obd2, i have to have it tested rather than using the plug in the ecu, correct?
Old Dec 3, 2003 | 05:16 AM
B A N N E D
someone said something about autozone being able to do it? is that true with the obd2 cars or only obd1?
Old Dec 3, 2003 | 06:48 AM
StyleTEG's Avatar
First fix your cam timming, if it still has problems and then throws a CEL worry about it then.
Old Dec 3, 2003 | 08:45 AM
B A N N E D
ok, thanks. valve adjustment will be done today and then i'l check the cel and see what's next. thanks.
Old Dec 3, 2003 | 07:18 PM
leadfoot78's Avatar
LOL!!! I fixed a car like that! It was running like ****! It would backfire all the time and wouldn't even rev past 3k(B16). Once you set it right, and turn the fuel psi up to like 42psi the codes might go away, thats what happend with my friends car. Be careful with the timing, turn the motor by hand and every 1/4 turn of the crank check the tention and timing. Also, time the ignition it with a timing gun.
Old Dec 4, 2003 | 05:14 AM
B A N N E D
Default Re: Motor Install-Lots of Problems...Help Me Out! (leadfoot78)
that's another thing. 42 psi for the fuel pressure? what is a good setting for the fuel pressure with the cam in it anyways? haven't had the chance to hook up an air/fuel gauge to see how its doing yet.
Old Dec 4, 2003 | 11:48 AM
B A N N E D
ok, update. my mechanic did the valve adjustment. they were WAY too tight from the machine shop. he had to loosen the timing belt as well. the cel says it's the crankshaft sensor. my question is this. on the obd2 oil pump, there are holes for where the screws go to hold the wiring in place for the sensor. when i installed it, there only seemed to be one way to install it. how can i tell if the sensor is bad or just installed incorrectly? that thing is like $100 at the dealership and i'd hate to have to spend more loot for nothing! thanks.
Old Dec 4, 2003 | 11:50 AM
StyleTEG's Avatar
have you fixed the cam timming yet?
Old Dec 4, 2003 | 12:07 PM
B A N N E D
yea, turns out the cam timing was fine. just the valves and timing belt were too tight.
Old Dec 4, 2003 | 12:57 PM
B A N N E D
i need an obd2 crank angle sensor. prefer one from a 99-00 si but a 96+ gsr will work. have cash. im me with what you got. thanks!
boostedb20ek
Apr 7, 2011 04:16 PM
hondaeg8
Oct 7, 2004 04:34 PM
poison
Jul 3, 2002 11:37 PM
MikeSarr_GSR
Apr 19, 2002 10:32 PM
erniecars
Apr 9, 2002 02:46 PM
