coolant in oil... blown head gasket?
ok heres the scenario:
jdm gsr swap in a 92 eg.
doin burnouts and over revved motor.
motor shuts off.
start car again and it sounds like a v8 with some crazy cams while blowing out very white smoke from the exhaust.
pull off the valve cover and there is a gunky coolant/oil mixture and no coolant in the reservoir.
is motor scrap?
head gasket? water pump? pistons? valves?
what should i check?
please help if you can. im keeping my fingers crossed hoping that it can be fixed. TIA
motor shuts off.
is motor scrap?
coolant in the oil sounds like a blown head gasket. as far as damage goes its hard to tell how much has been done. youre just gonna have to rip it apart. take the head off and check it out. since you over-reved you may have done some serious damage up there. with the idle like you said you probably screwed up a valve or 2. but check everything you already stated. it may be time for a rebuild.
problem is im no mechanic. i have a helms and i can pull the head and put in a new head gasket but that about it.... as for pistons and valves and all that stuff im lost
thanks for the info guys. i got a b16 that im gonna drop in my car for now and sometime i have to pull the head but its soooo cold outside and i dont have a garage to work in. anyone want to volunteer to come check out my motor? ill buy you some beer
Malt-liquor
12
Apr 11, 2018 06:29 AM
djviet2000
23
Apr 29, 2008 09:36 PM
HondaFanatic708
Apr 12, 2004 02:45 PM
