Stuck Screw
Old Nov 30, 2003 | 11:51 AM
ExiledinIN's Avatar
Default Stuck Screw
Tried everyting (screw extractor, Craftsman Screw outs, slot head, vise grips. After the vise grips, it ripped the head off. Then tried an extractor and it broke off inside. So, the only thing I have is this:
Any suggestions on how to get it out? I think that there is a good amount of rust on the bottom of this that is making it difficult to get out.
Old Nov 30, 2003 | 11:52 AM
ExiledinIN's Avatar
Default Re: Stuck Screw (ExiledinIN)
One other thing. That center is the extractor (hardened).
Old Nov 30, 2003 | 11:54 AM
pdiggitydogg's Avatar
cut a slot in it and use a flat head
if that doesnt work, cut the extractor section out, then use a bigger one
edit**oh and try a manual impact driver from craftsman when you cut the slot (around $25 and great for brakes too)
Old Nov 30, 2003 | 11:57 AM
92b16vx's Avatar
Use a torch to heat it up before you try to remove it again, it will help.
ExiledinIN's Avatar
Default Re: (pdiggitydogg)
hmm, interesting. got the sears impact driver already from wife's brake job.
ok, i'll run out and see if that'll do it.
Old Nov 30, 2003 | 12:42 PM
BauleyCivic's Avatar
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">cut a slot in it and use a flat head
Interesting idea... I'll have to keep that one in mind.
Old Nov 30, 2003 | 12:43 PM
ExiledinIN's Avatar
Default Re: (ExiledinIN)
I cut the screw below the extractor and made a slot. The impact driver just ended moving the material on top (think maybe not enough material given that the screw is pretty small and the impact is BIG.
How do I drill out the screw? And if I do this, do I have to retap the hole?
Old Nov 30, 2003 | 01:01 PM
salbaje's Avatar
are you able to screw in a nut?? if you can screw in 2 nuts and tighten and then try to loosen the inner one
Old Nov 30, 2003 | 01:24 PM
ExiledinIN's Avatar
Default Re: Stuck Screw (salbaje)
No, it is now flush w/ the floor. How would I drill it out?
Old Nov 30, 2003 | 04:26 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
ok this happens all the time on jets and these are your best 2 options.
1: make a slot for a flat head or something of the sort and tap it off!
2: get a titanium drill bit to get thru the extractor but make sure its smaller then the bolt its self so that you don't mess up the treads. once your in pretty good it will twist right off.....
where is this bolt your having trouble with?
Old Nov 30, 2003 | 04:57 PM
Sleepy03's Avatar
ok you said in you last post its "flush with the floor" so now you need to drill it out and retap
1. use a center punch on the screw.
2. use a drill bit smaller than the screw also note how far the screw goes in, don't drill too far threw.
3. retap the hole, I use a cutting fluid called "Tap magic" it helps alot.
Old Nov 30, 2003 | 05:05 PM
rob d's Avatar
Default Re: (SnoFlake EG)
[QUOTE
where is this bolt your having trouble with?[/QUOTE]
This is what I do some times. If you have access to a welder, weld a bar on top and twist away. This works for me every time.
Old Nov 30, 2003 | 05:36 PM
The Internet Tough Guy's Avatar
Default Re: (rob d)
just get some jb weld and some cheap *** pliers or a screwdriver. weld that **** on, wait a couple hours and voila!
JBirch_97Prelude
Jun 28, 2008 09:24 AM
iwhichisme
Sep 6, 2004 05:22 PM
W.O.P.
Apr 28, 2004 03:34 PM
AznJohn33
Jan 10, 2004 08:58 AM
type autox
Jan 21, 2002 06:55 PM
