stripped out screw head, any options?
Old Jan 21, 2002 | 12:11 PM
type autox's Avatar
New User
Default stripped out screw head, any options?
Its the screw on the distributer rotor. the little bleeder was in so tight I stripped it trying to get it out! what now? thanks for any advice.
Old Jan 21, 2002 | 06:35 PM
VTECVillain's Avatar
Default Re: stripped out screw head, any options? (type autox)
I had the same problem on my stock motor when I first bought my car. I used a really small drill bit and drilled it just a little and used an EZ Out and it came off pretty easily. That's how I usually remove stripped screws. When that doesn't work I sometimes use a dremel with a saw disc and cut a notch across the head then use a flathead screwdriver to remove it.
Old Jan 21, 2002 | 06:55 PM
HaUTSaauce's Avatar
New User
i go with the dremel technique
JBirch_97Prelude
Jun 28, 2008 09:24 AM
W.O.P.
Apr 28, 2004 03:34 PM
FcUK It.
17
Oct 9, 2003 03:18 PM
ih8danoles
Apr 21, 2003 12:21 PM
uber_nihilist
Apr 27, 2002 04:23 AM
