Please Help!!! charging system?
Old Nov 30, 2003 | 07:26 AM
BAZ's Avatar
BAZ
Default Please Help!!! charging system?
OK, my friends '93 Accord LX has been acting kinda weird for the last couple of weeks. Every time she starts her car, either the clock or the radio resets and sometimes both. It starts fine and there's no check engine lights. Battery connections seem to be fine. Whats the deal?
Old Nov 30, 2003 | 08:47 AM
BAZ's Avatar
BAZ
Default Re: Please Help!!! charging system? (BAZ)
anyone?
Old Nov 30, 2003 | 10:08 AM
Chiovnidca's Avatar
Have you checked the backup fuse in the underhood fusebox?
Old Nov 30, 2003 | 10:18 AM
BAZ's Avatar
BAZ
Default Re: Please Help!!! charging system? (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Have you checked the backup fuse in the underhood fusebox?</TD></TR></TABLE>
I'm kind of unfamiliar with this "backup fuse" can you elaborate on what it does?
*EDIT* Searched and found out the backup fuse function. Is this going to affect anything besides resetting ecu, radio, clock??? Is it detremental to the vehicle in any way?
Modified by BAZ at 1:33 PM 11/30/2003
Old Nov 30, 2003 | 10:46 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BAZ &raquo;</TD></TR><TR><TD CLASS="quote">
It holds the memory for the radio, clock and ECU when the car is off.
Old Nov 30, 2003 | 12:02 PM
BAZ's Avatar
BAZ
It holds the memory for the radio, clock and ECU when the car is off. </TD></TR></TABLE>
Not necessarilly bad for the car though, right?
Old Nov 30, 2003 | 12:06 PM
Chiovnidca's Avatar
Not necessarilly bad for the car though, right?</TD></TR></TABLE>
If the car is running ok I wouldn't worry about it. Are you so lazy you don't want to check a fuse?
Old Nov 30, 2003 | 12:09 PM
BAZ's Avatar
BAZ
If the car is running ok I wouldn't worry about it. Are you so lazy you don't want to check a fuse? </TD></TR></TABLE>
haha! no, I'm at work right now. Just trying to get some info. and kill time before I go home. Thanks a lot for your help, much appreciated.
atown40s
Aug 28, 2008 03:22 AM
integra123456
Jan 13, 2008 09:47 PM
rukawa1one
Feb 18, 2005 04:31 PM
lilpymp
Feb 4, 2005 11:52 AM
99fbpem1
23
May 18, 2003 02:54 PM
