clock and radio resets
i installed a new cd player and forgot to take out the negative from the battery. now they both reset. i checked and no blown fuse. help!
Re: clock and radio resets (lilpymp)
Did you check the underhood fuse box where the backup fuse for the items you are asking about is?
It's a 15a fuse I think.
Re: clock and radio resets (Ricey McRicerton)
ok i'll check. how come the fuse under the steering panel's not blown? that's the one that should blow first right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Did you check the underhood fuse box where the backup fuse for the items you are asking about is?
It's a 15a fuse I think. </TD></TR></TABLE>
for EG's is a 7.5 A fuse marked "Back-up"
the the ciruit that keeps your clock, radio, and ecu powered when the ignition is turned off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilpymp »</TD></TR><TR><TD CLASS="quote">ok i'll check. how come the fuse under the steering panel's not blown? that's the one that should blow first right?</TD></TR></TABLE>
No. Trust me. I've destoryed mine and pulled it more times than I can count. And yes, now that you said 7.5a, that sounds right.
hondaEg_808
10
04-19-2008 12:40 PM
truevietluv636
03-01-2007 09:46 PM
wu4607
05-23-2006 06:57 PM
