blinker fuse
blinker fuse
My running lighs, break lights, all lights are working but my blinker does not work, is it a fuse and if it is where is this fuse, under what name? if it's not a fuse what is it? running lights do work, ne help would be great
Re: blinker fuse (j.fuggi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j.fuggi »</TD></TR><TR><TD CLASS="quote">check your blinker fluid </TD></TR></TABLE>
Someone had to say it.....
Check your fuse box. The cover should point out where the fuse is and if your fuse is ok and you have done no "mods" to your turnsignals then you might just need a new bulb.
damn thats what i was going to say
Re: blinker fuse (silverEH2)
yah but the running lights work, the bulb isn't blow just the blinker doesn't work, that light works, running lights and blinker on the samen fuse?
Re: blinker fuse (95civicdx)
Relay, maybe. On some vehicles, if one of the bulbs is out on one side, the opposite end(on the same side) will blink faster than normal-or not work at all.
here is my exact situation plz help, all of my lights worked before i started
I was putting some indiglo guages in my car and accidently blew my running lights fuse, so i replaced that only to find out that now my blinker doesn't work, but all of the lights do, is it possible that i put the wrong kind of fuse in? if so what is the correct kind of fuse? plz help me
i coudn't find the clock fuse, and my hazards work, and i checked all of my bulbs, could it be a problem with the wire? my hazards to work, just when i flip the blinker the dash lights don't indicate a blinker and the light don't blink, could it be a problem with the wire? please help me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civicdx »</TD></TR><TR><TD CLASS="quote">i coudn't find the clock fuse
Sorry, it should be listed as: "Back-up light" in the under dash fuse box. It's a 10 amp.
Hey, about the blinker fuse topic, i checked the back up light fuse and replaced it just to be sure, and still nothing, any other ideas on what it could be?
Re: (95civicdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civicdx »</TD></TR><TR><TD CLASS="quote">Hey, about the blinker fuse topic, i checked the back up light fuse and replaced it just to be sure, and still nothing, any other ideas on what it could be?</TD></TR></TABLE>
Probably a wiring problem then.
Re: (95civicdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civicdx »</TD></TR><TR><TD CLASS="quote">Any idea how much something like that would cost to take in?</TD></TR></TABLE>
About 1 hour labor to check out. $65-$70 in my area.
Re: (Chiovnidca)
thanks for the help, one more question y is there a black plastic thing in one of my fuse places on the underside it's on the far top left side (closest to the door drivers door) it's a black plastic peice, it's like it's blocking the fuse spot, ne idea what this is?
New User
Re: blinker fuse (EF9_SiR)
hmmm if your emergency flashers work and you hear the TICK's, then you can trace it by feeling the right relay.
Ummm its one of the small black squares next to your fuse box. couldn't tell u exactly, perhaps a search will bring up a diagram?
Re: blinker fuse (Pritos)
i need more info on this relay, sounds like it's my problem, if it is blown what do i do? and what does the relay look like? does it say any thing on it? black you say?
plz help
plz help
New User
yeah its a black square about 1"x1". Do you have a neighbor that has a working civic? Have them turn on the blinkers to u can trace the location.
bad relay=no blink or strange blinking.
i turned my hazards on and they work so that's how i found the relay, so is the relay my problem and if it is what do i do now?
tdubbebawllin
07-29-2008 01:34 PM
