15 psi in crx si?
what do i have to do to run around 15 psi in stock crx 91 si d16a6? or the dohc zc non vtec ? if i have to put the lower comp piston , so where i can find it? i am in lower budget . i will apperciate some coments
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">rebuild the bottom end with forged internals.
15psi is way too much on a stock bottom end.</TD></TR></TABLE>
True, get eagle rods and JE pistons, its a good setup and fairly cheep, and then you can even run 20 psi, make sure you have a good fuel managment system, 450 CC injectors and air/fuel guage and boost guage so you know what youre boosting at, also ger a good head gasket and use a block guard or just post the block, some good info at:
http://www.homemadeturbo.com
