bulding bottom end
Old May 14, 2003 | 08:27 PM
hollaback6's Avatar
Default bulding bottom end
well i am going to be building my bottom end soon. I was planning on getting eagle rod but not sure what pistons and if i should sleeve the block and get a block guard. Is it possible to do all this for a grand. I was planning to run at least 15 psi on a 16g or 20g turbo.
Old May 14, 2003 | 09:16 PM
b16ahybrid's Avatar
Default Re: bulding bottom end (hollaback6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hollaback6 &raquo;</TD></TR><TR><TD CLASS="quote">well i am going to be building my bottom end soon. I was planning on getting eagle rod but not sure what pistons and if i should sleeve the block and get a block guard. Is it possible to do all this for a grand. I was planning to run at least 15 psi on a 16g or 20g turbo.</TD></TR></TABLE>
You could probably get all the parts for about a grand (pistons,rods and sleeves) but labor will run you a lot more.
Old May 14, 2003 | 10:06 PM
Copy Cat's Avatar
Default Re: bulding bottom end (b16ahybrid)
how much is the labor for sleeving? and is the price range of sleeves (ball park's cool)
Old May 14, 2003 | 10:11 PM
hollaback6's Avatar
i was most likely going to be doing most the labor my self with the help of a friend.
Old May 14, 2003 | 10:16 PM
ion_four's Avatar
I don't think you could sleeve the engine yourself, though you might be able to get it done for cheap with the Darton "modular" sleeves...Eagle Rods/JE Pistons can be had for well under $700, but then you have all the bearings, new head gasket, head studs, new oil pan gasket...might as well replace the oil pump and get the crank micropolished...so, **** starts to add up. I think if you shopped around you could get all of the stuff with a blockgaurd for under $1000, including incrementals (assembly lube, rtv, random tools, etc.)
I'm looking into prices for my d16z6 and I'm trying to cypher out what to do...
Old May 14, 2003 | 11:16 PM
BoostedSi's Avatar
Default Re: bulding bottom end (ion_four)
ditch the blockguard idea.
Old May 15, 2003 | 12:58 AM
T-sohctec's Avatar
I just put 250 miles on my newly built Z6.
here's the breakdown.
free Bare Z6 block
Mains needed line hone $140
crank kit ( new crank W/ ACL bearings 240$)
forged pistons B16 rods $500
oil pump & main seal 150$
Honda head gasket $80
$800 in it roughly.
I did all the work myself so I saved alot there.
It can be done.
Old May 15, 2003 | 06:23 AM
Dorikamu's Avatar
Default Re: bulding bottom end (T-sohctec)
a sleeved block runs you about 950 (darton stage 2). talk to vs racing.
I suggested you to run 5-7psi with stock sleeves if you only have a grand to work with. Just upgrade the piston and rings & get new bearings. Save the money for Hondata/tuning if you haven't done it already.
And you dont need a blockguard with low boost.
Old May 15, 2003 | 08:14 AM
ITRTurbo's Avatar
which company does the micropolishing of the crank?
Old May 15, 2003 | 09:04 AM
ExospeedAMcrx's Avatar
We have been doing the Sleeving, Arias piston and Eagle rods package for about $1700.00 stock bore to overbore sizes. I would suggest sleeving if you are going 15psi+. The block is all honed, bored, decked, etc and ready to assmeble.
Old May 15, 2003 | 09:07 AM
alpha's Avatar
What are your power goals?
Old May 15, 2003 | 10:14 AM
hollaback6's Avatar
my goal is 400whp basically. Right now i have only a t25 runing 10 psi daily but want to upgrade to probably a 20g because i don't think a 16g could make that kind of power. I was going to buy a shortblock and build it. I want to do it right the first time. i was hoping to run like 15psi daily and 20 at the track. thanks.
blinx9900
Jul 21, 2007 11:50 PM
themorphious
Aug 1, 2006 09:52 PM
ChrisUlrich
Honda Civic (2001 - 2005)
Jun 24, 2006 10:02 PM
done
Aug 23, 2004 12:25 AM
roots01
Feb 2, 2004 01:45 PM
