Ordering pistons some help would be nice!!!!
Old Nov 26, 2003 | 10:16 AM
B18c1turboedEK's Avatar
Default Ordering pistons some help would be nice!!!!
Ok im ordering pistons but i dont know much about compression ratio and all that so please help..
I have a gsr block
Eagle rods
Blockguard
Headgasket
apr headstuds
turbo running a sc61 using a inline pro manifold,tial wastegate
what piston size should i get to make as much HP as possible
P,s NOT SLEeVING BLOCK!!!
Old Nov 26, 2003 | 10:19 AM
b18bturbo's Avatar
Default Re: Ordering pistons some help would be nice!!!! (Koticcivic4u)
stock bore aroudn 9.1 compression should be ideal for you without a sleeved block..
You can go with CP, Wiesco or JE or any brand really.
Flamenco-T's Avatar
if you're not sleeving your block, then your option is either 81 or 81.5mm
As far as compression, with SC61, I would get 9.5:1 at the lowest and 10:1 will be optimum to me.
stan
Old Nov 26, 2003 | 10:20 AM
93LSivic's Avatar
Dont overbore unless its absolutely necessary. BUT, have the bores checked at a machine shop to see....inspection is more than the naked eye.
Honestly, your question is pretty vague.
But if compression is what your after I would say nothing less than 9:1 and nothing more and 9.8:1
Stay away from JE 81mm 9.8's though.
Old Nov 26, 2003 | 10:26 AM
Default Re: Ordering pistons some help would be nice!!!! (93LSivic)
Im sorry for being so vague,,, im looking to stay standard size so i dont have to bore out, i was just looking for best compression to run on the sc61 and have the power and be happy with it...
Old Nov 26, 2003 | 10:32 AM
MotorMatrix.com's Avatar
I am a bad person
try to stay stock bore at 9:1 to be safe. I personally wouldnt even bother building an unsleeved motor. too many people making good hp on stock bottom end. save your money until you can afford to sleeve it.
Old Nov 26, 2003 | 10:48 AM
Default Re: Ordering pistons some help would be nice!!!! (MotorMatrix.com)
Thanks motor matrix.... thats what i was thinking about doing..but alot of people tell me too atleast put pistons and rods to be safe.. I had a friend dyno in at 440 on a t3 60-1 turbo last week on a stock block also i was impressed!!!!!
eg:R
Oct 18, 2007 05:56 PM
mikemskater
Apr 8, 2007 08:05 PM
lsturbo*
Sep 16, 2006 05:24 PM
hioutput
Jun 12, 2005 09:19 AM
done
Apr 29, 2002 06:04 AM
