help on build block picking pistons
Old Oct 17, 2007 | 06:18 PM
eg:R's Avatar
Default help on build block picking pistons
my motor now is a sleeve build lsvtec. gsr head(81mm 9:1). planning on rebuilding the block to 84.5mm 10:1 compression. will this be ok with a gsr head? the car is a daily driven. im sure the compression bump to around 10.5 due to the gsr head. just wondering if that will be ok or should i just get 9:1 84mm piston
Old Oct 17, 2007 | 07:03 PM
MeanGreenMachine's Avatar
Default Re: help on build block picking pistons (eg:R)
wiseco cp j.e. srp arias.
choose....
Old Oct 17, 2007 | 09:21 PM
Topdawgg's Avatar
Default Re: help on build block picking pistons (MeanGreenMachine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeanGreenMachine &raquo;</TD></TR><TR><TD CLASS="quote">wiseco cp j.e. srp arias.
choose....</TD></TR></TABLE>
not once did he ask for a brand to choose....
GTFO and read his ****** thread before u post useless ****..
anyways... Id go with a lower compression dude.. just play it safe... ive got an 84mm LS with 9.0:1 compression and its makin great power on pump and race gas.. LOTS more in this
Old Oct 17, 2007 | 09:29 PM
SD_Lurker's Avatar
HT White Ops
Default Re: help on build block picking pistons (Topdawgg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">
anyways... Id go with a lower compression dude.. just play it safe... ive got an 84mm LS with 9.0:1 compression and its makin great power on pump and race gas.. LOTS more in this</TD></TR></TABLE>
Wow be careful before posting something like that. Make sure you are 100% certain that your correct because if you read the title it specifically states help picking pistons!
Old Oct 17, 2007 | 09:34 PM
Blind-Fashion's Avatar
I have always like Endyne/wiseco's Rollerwaves.
I have used them on 3 turbo setups and 1 all motor setup. I was 13.2:1 with the all motor and i was able to tune out all detonation and still able to make 254 on pump gas and a portflow head.
On the turbo setups I've been able to run a shitload of boost on pump gas without any detonation. (one 10:1 84mm with gsr head netted 10.7:1 with all the milling of the head & block made 527 on 17pounds pump gas and 637whp 28psi on race gas the car in my sig)
Stefan ( 98CTR owner of ASP performance) made 630whp on PUMP GAS (no bullshit, i was there) with 10:1 compression with the same pistons.
The rollerwave "design" just seams to work
I know the compression seams awefully high, and maybe i've just had good luck but thats what has worked great for me.
If your going with any other brand, i'd recommend 9:1. either way you go, just take my advice with a grain of salt, everyone has there own opinions mixed with real life experiances and what they read on here..
Old Oct 18, 2007 | 02:53 AM
Topdawgg's Avatar
Default Re: help on build block picking pistons (SD_Lurker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SD_Lurker &raquo;</TD></TR><TR><TD CLASS="quote">
Wow be careful before posting something like that. Make sure you are 100% certain that your correct because if you read the title it specifically states help picking pistons!</TD></TR></TABLE>
yea... needs helping picking pistons... not help picking a brand of pistons
Old Oct 18, 2007 | 04:11 AM
LOL....
Old Oct 18, 2007 | 05:56 PM
eg:R's Avatar
my bad guys i needed help on picking piston compression on next rebuild. im current running 9:1 and i wanted to see if 10:0 compression is going to be too much for 84mm with gsr head. im sure that will bump up the compression a little over 10:0's. i read a lot of rsx running stock compression 11:1 with turbo and i was just thinking if 10's flat will be okay or just stick to 9:1 dish.
stealth50k
Jul 6, 2008 01:13 AM
ELPITUDO
Jun 26, 2007 06:19 AM
mikemskater
Apr 8, 2007 08:05 PM
hioutput
Jun 12, 2005 09:19 AM
yellowmonkeyboy
Oct 1, 2004 03:38 PM
