LS+b16tranny+turbo= good or bad??????
Old Nov 25, 2003 | 11:19 PM
sPaRk'iT's Avatar
Default LS+b16tranny+turbo= good or bad??????
95LS with a b16 tranny, or should i stick with my LS tranny??? i will be boosting.
Old Nov 25, 2003 | 11:23 PM
Killer_B's Avatar
Default Re: LS+b16tranny+turbo= good or bad?????? (sPaRk'iT)
stick with the Ls tranny.
i had an Ls with all 3 trannies, Ls, Gsr and B16. the Gsr by far was the best. with the B16 tranny and 6,800rpm rev limit, your car will rev out too quick.
Old Nov 25, 2003 | 11:31 PM
Hoosier Daddy's Avatar
Default Re: LS+b16tranny+turbo= good or bad?????? (Killer_B)
LS
Old Nov 25, 2003 | 11:39 PM
sPaRk'iT's Avatar
Default Re: LS+b16tranny+turbo= good or bad?????? (Hoosier Daddy)
how about a Gsr and a Ls?? which one???
Old Nov 25, 2003 | 11:52 PM
liam821's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sPaRk'iT &raquo;</TD></TR><TR><TD CLASS="quote">95LS with a b16 tranny, or should i stick with my LS tranny??? i will be boosting.</TD></TR></TABLE>
I have no idea what all of you are smoking....use the b16a tranny for sure. Why? Because with the short gearing its easy to adjust it for the size of tires. What a longer 5th? Put on a bigger slick. With a LS and big slicks you have such a huge 5th gear its just silly.
Almost all the fast ProAM guys run b16a...and its easier to drive around town with.
liam
Old Nov 26, 2003 | 04:38 AM
Mr.DC2TurBo's Avatar
Depends on how you drive, hehe. If you like driving all fast and quick at each lite, then b16 all the way. But, if you are a daily driver and do a lot of freeway driving LS tranny is better on gas and lower revs while driving. In my opinion b16 is good for the quarter mile and LS is good for the freeway chases up at the top end. Depends on you bro, either one is good.
Old Nov 26, 2003 | 06:13 AM
TurboB18B's Avatar
Default Re: LS+b16tranny+turbo= good or bad?????? (Mr.DC2TurBo)
I would use the LS tranny. The B16 tranny is setup with closer gearing to maximize the vtec and keep you in your power band. An LS with the longer gear ratios will maximize the power of the turbo and you will be in boost longer. i have an LS integra so I dont have a choice, but 3rd gear in my car is long and nasty with my turbo setup. Regardless of what you do, you will not save gas either way because the turbo and your right foot will use it all up
Old Nov 26, 2003 | 06:32 AM
99lspwr's Avatar
Default Re: LS+b16tranny+turbo= good or bad?????? (TurboB18B)
If this thing will be at the track at all, go w/ ls tranny or be prepared to have a tall *** tire!!The car will run out of gear w/ a b16 tranny...
Old Nov 26, 2003 | 06:46 AM
MIKES's Avatar
Default Re: LS+b16tranny+turbo= good or bad?????? (99lspwr)
use the tranny that belongs to that motor. Put the LS on if you don't mind pulling power away from your setup. LS is a lazy tranny with a vtec motor. Yeah you stay in each gear longer and shift less but at what trade off?, a lazy powerband. rpm is hp period. All the LS tranny is doing is just slowing down your rpms.
Old Nov 26, 2003 | 07:26 AM
STHPERFORMANCE's Avatar
Default Re: LS+b16tranny+turbo= good or bad?????? (MIKES)
i would get yourself a GSR w/ Quaife Lsd ......
if the car is gonna be highway driven u could look into a LS 5th gear so u arent driven at such a high RPM while cruising on the highway.....
But all and all GSR is the best IMO...
Old Nov 26, 2003 | 09:17 AM
dabrown's Avatar
Default Re: LS+b16tranny+turbo= good or bad?????? (Outkast)
I vote for LS first then GSR second, unless your building strictly drag.. The b16 and Type R tranny has really short gears. When boosting it's just uncomfortable unless your quick on the gears..
Old Nov 26, 2003 | 09:24 AM
rocket256's Avatar
i'd listen to "99lspwr" he is right. i have a gsr in my coupe. at the end of the 1320. im still in third at 96mph. as where my friend david; he has a b16. he is well in 4th at 92mph! but we any have intake, header and exhaust!
Old Nov 26, 2003 | 10:10 AM
froggie3kb's Avatar
Default Re: LS+b16tranny+turbo= good or bad?????? (rocket256)
I cant speak for the turbo part, but a friend of mine has a full ls swap in his 94 cx with i/h/e and at our 1/8th track i consistenly pull him by .2-.3 tenths every race and all i have is i/e with just having a gsr tranny.
Old Nov 26, 2003 | 10:20 AM
BlueSi2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB18B &raquo;</TD></TR><TR><TD CLASS="quote">I would use the LS tranny. The B16 tranny is setup with closer gearing to maximize the vtec and keep you in your power band. An LS with the longer gear ratios will maximize the power of the turbo and you will be in boost longer. i have an LS integra so I dont have a choice, but 3rd gear in my car is long and nasty with my turbo setup. Regardless of what you do, you will not save gas either way because the turbo and your right foot will use it all up </TD></TR></TABLE>
being in boost longer isn't making you faster...bottom line your going through the gear slower therefore accelerating slower. Your in boost longer in a 4th gear pull then a 2nd gear pull...does your car accelerate faster in 4th or 2nd?
Old Dec 1, 2003 | 08:17 AM
Killer_B's Avatar
Default Re: LS+b16tranny+turbo= good or bad?????? (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 &raquo;</TD></TR><TR><TD CLASS="quote">
liam</TD></TR></TABLE>
i believe we're talking about a street car. B16 tranny + Boost for daily driving is annoying to say the least and thats not even considering the horrible gas milage that you're going to have.
Old Dec 1, 2003 | 12:59 PM
rocket256's Avatar
Killer_B
is right!
Old Dec 4, 2003 | 08:53 AM
sPaRk'iT's Avatar
thanks for all the replys...i think im going to look for a GSR tranny, but at the same time ill be using my LS tranny for a while.
thanks,
Bruce
Old Dec 4, 2003 | 09:23 AM
System-7's Avatar
i saw this on SCC magazine , a GS-R turbo with Type-R gearing 1-4, and LS 5th, good for quarter mile and highway, since the 1-4 of the type-r keep it on boost, and 5th for highway for longer gear
Old Dec 4, 2003 | 06:21 PM
Killer_B's Avatar
Default Re: (System-7)
B16 is VERY simular to Type R, except Type R has LSD.
2wheelhunter
Dec 28, 2006 05:56 PM
a2dadamm
Dec 29, 2005 01:24 PM
JSPECCRX
May 19, 2005 09:17 PM
jarvis199
May 7, 2005 07:51 AM
cliff666
Sep 30, 2003 09:32 PM
