TPS Sensor Removal
no no no...what u need to do is dremel a slot in the two attaching shear bolts and remove them with a regular flat head screw driver. The shear bolts are screwed in like regular screws but the heads are taken off or sheared off to prevent loosening and removal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 »</TD></TR><TR><TD CLASS="quote">no no no...what u need to do is dremel a slot in the two attaching shear bolts and remove them with a regular flat head screw driver. The shear bolts are screwed in like regular screws but the heads are taken off or sheared off to prevent loosening and removal.</TD></TR></TABLE>
what he said.. use a small saw or a dremel with a sharp cutting bit and cut a slot into the ends of the tps screws, then use a flathead screwdriver. Remember to align your new tps when u put it on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportsCRX »</TD></TR><TR><TD CLASS="quote">why would u want to take ur TPS Sensor off?</TD></TR></TABLE>
I just changed the engine...When I put in the new one I realized that the connector portion of the new sensor was broken, but I didnt know how to change it...So i just taped the connector to the exposed connections and drove it...but it needs to be changed. thanks for all the replies!
I just finished posting a DIY for this very thing in another thread.
Click here to check it out Complete with pics...lol
b18 hatch mike
Jun 11, 2007 04:25 PM
91integraLSVTEC
Nov 11, 2005 10:38 PM
ArchAngel Sabastian
Apr 10, 2003 12:31 PM
?? Please help!! Thanks
