Help w/ TPS Sensor: how to remove?
Old Dec 18, 2005 | 10:53 PM
foam's Avatar
Default Help w/ TPS Sensor: how to remove?
I haven't looked at it yet but I am going to have to replace my TPS sensor. There is rivets that I need to remove to take it off? I just am wondering how people removed the rivets as I was told they are hard to remove.
Old Dec 18, 2005 | 11:49 PM
96Spec Ek's Avatar
Default Re: Help w/ TPS Sensor: how to remove? (foam)
You can grind the rivets end off and just use bolts to reinstall the new one. There are threads where the rivets were.
Old Dec 19, 2005 | 09:22 AM
Katman's Avatar
if you take a dremel and slice a nice semi-deep line into the rivets, you can use a flat head screwdriver to unscrew the rivets.
Old Dec 19, 2005 | 02:56 PM
jz98ctr's Avatar
Default Re: (Katman)
I concur with Katman
simple...easy....effective
Old Dec 19, 2005 | 03:32 PM
foam's Avatar
Default Re: (jz98ctr)
I think I might go with the dremel approach.
Old Dec 19, 2005 | 05:10 PM
Redline130's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">if you take a dremel and slice a nice semi-deep line into the rivets, you can use a flat head screwdriver to unscrew the rivets.</TD></TR></TABLE>
That's how I always take them off.
Old Dec 22, 2005 | 12:37 AM
danerr's Avatar
thanks guys. my tps sensor failed on my h22a4, i used a dremel just as you said and swapped in a tps sensor from an accord (f22 i beleive). it worked perfectly. make sure you cut deep so your flathead doesnt strip it or slip.
Old Jan 5, 2006 | 11:33 AM
mcspd704's Avatar
what effects did the bad tps sensor cause. Loss of power when trying to reach WOT or rev up?????????? when i get on the gas slowly, it runs fine!!!!!!!i got a bad tps and that's what's happening in my car
Old Jan 5, 2006 | 11:34 AM
mcspd704's Avatar
Default Re: (Redline130)
mr. redline what are the effects of a bad tps
Old Jan 5, 2006 | 03:35 PM
Tippyman's Avatar
They're threaded?
Old Jan 5, 2006 | 04:17 PM
JDM00SI's Avatar
Default Re: (Tippyman98)
i have this bookmarked..... i will be removing tps soon.
Old Jan 5, 2006 | 09:56 PM
amckee's Avatar
Default Re: (mcspd704)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcspd704 &raquo;</TD></TR><TR><TD CLASS="quote">mr. redline what are the effects of a bad tps</TD></TR></TABLE>It varies. Some cars stumble in midrange acceleration. If it sets a code economy will suffer. Automatics won't shift right. The TPS is what triggers the fuel injector cutoff when the throttle plate is closed and the RPM is over 1100-1200 such as during decelleration in gear or during gear change. It may be an EGR enabler/dissabler, but I'm not sure about that one. I'm sure there are other functions. Many manual trans cars will run fine on default with a bad TPS.
Old Jan 8, 2006 | 05:48 PM
danerr's Avatar
Default Re: (amckee)
with a bad tps the ecu cant tell you are pushing the gas pedal. your car will keep cutting the fuel every time the rpms reach 1400-ish, because the ecu thinks its idling too high.
Katman, yes they are threaded.
Old Jan 8, 2006 | 07:03 PM
amckee's Avatar
Default Re: (danerr)
Usually they don't go totally bad. They just develop dead spots that may cause a stumble, the driver will usually push the gas harder and get past the dead spot. This may or may not set a code. Where it develops the dead spot will determine how the engine reacts.
billyzakkus
Dec 4, 2008 02:17 PM
EX-T
Sep 2, 2008 04:33 PM
CRX30436
Feb 6, 2008 07:00 PM
kornerk12
Jun 15, 2007 04:01 AM
russianswty
Dec 23, 2006 09:20 AM
