Done turbo install!! 1 problem though!!! Dam injectors don't fit...Help!!
Old Nov 21, 2003 | 11:06 PM
roydogg's Avatar
Default Done turbo install!! 1 problem though!!! Dam injectors don't fit...Help!!
Okay I'm done everything. Workin on this install all week to get ready for tomorrows dyno day and I'm fucked because of the dam injectors not fitting.
My setup consist of a 18g turbo on a 94 b18b with a hondata s200. Last thing to do was to put the obd2 310cc greddy injectors in and they just won't go into the manifold . They do fit into the rail with no problems. The top part of the injectors in the pic are different sizes, could that be the problem?
The injectors came off a 2000 gsr, are there any differnce in injector sizes from obd2 vehicles to obd1 cars.
I need help asap!!!
Old Nov 21, 2003 | 11:14 PM
psi420's Avatar
The part where the rubber ring goes, between injector and manifold, try boring it out a little. Thats the only size difference.
Old Nov 21, 2003 | 11:23 PM
Flamenco-T's Avatar
Default Re: (psi420)
damn you beat me to it Ryan
Roy,
use a dremel or rotary tool and dremel it out until the injectors fits in the manifold.
stan
Old Nov 21, 2003 | 11:38 PM
roydogg's Avatar
Default Re: (Flamenco-T)
Just did it and it works!! The only problem is that I tried it on my spare motor and it's now 4am 35 degrees outside . And I really don't feel like taking my fuel rail and injectors out again so I'll try early in the morning if I can get up.
Hopefully I can get done to get dynoed.
Thanks guyz! Have a good night.
S2000Forsale
Honda S2000
Sep 28, 2007 11:26 AM
ragethemachine86
Aug 11, 2006 05:52 AM
drumking15
Apr 3, 2005 08:52 AM
magic hat #9
Apr 22, 2004 08:19 PM
JDEM1
Jun 20, 2003 09:44 AM
