Precision Injectors Install problem
Old Apr 3, 2005 | 07:46 AM
drumking15's Avatar
Default Precision Injectors Install problem
Ok everything was going great putting my motor back together and then i went and grab my injectors...put the new seals & grommets on them...put them in the intake mani and put the fuel rail on....now i go to plug in the clips to the injectors...ya so they didnt fit...i was like wtf....these are suppose to be precision 780cc injectors....from looking at my obd1 clip and the injector it seems like 1 lil plastic pin in the injector is stoppin the plug from going on....could it be an obd2 injector....any help is greatly appreciated!!!
Old Apr 3, 2005 | 07:52 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Precision Injectors Install problem (drumking15)
All you have to do is clip/trim off the middle plastic with a razor knife and it should fit snuggly. I am assuming that they are P/H style injectors.
Old Apr 3, 2005 | 08:01 AM
drumking15's Avatar
ya thats what i though...just makinbg sure before i start cuttin up $300 injectors
and yes they are p/h
Modified by drumking15 at 12:52 PM 4/3/2005
Old Apr 3, 2005 | 08:06 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: (drumking15)
I have a set of Delphi 950cc in my hatch and cutting up the middle piece is not a big concern of mine. And if I was to ever resell them, the only thing the new owner have to do is use OBD I connectors.
Old Apr 3, 2005 | 08:17 AM
1Bar GSR's Avatar
Default Re: (NVturbo)
I had the same problem with my 1000cc injectors there is just a little bit to trim off with a razor blade... if you look at both of them you can see what you need to trim off. It should snap on just fine afterwards! Good Luck!
Old Apr 3, 2005 | 08:52 AM
drumking15's Avatar
awesome...going to cut them know...using some of my engineering tools...ya exacto knife
SiR99
Apr 29, 2006 10:18 AM
kabaroo
Jun 28, 2005 11:53 AM
Black R
Jun 17, 2004 01:34 AM
95gsr
Mar 3, 2004 04:50 AM
ladysman
May 26, 2003 01:50 PM
