wiring tech help needed asap!!!
Old Nov 20, 2003 | 07:16 PM
dingusjt's Avatar
Default wiring tech help needed asap!!!
in my many month quest to solve my code 14 (eacv) with my d15b2 i'm still getting a damn check engine light...but now i seriously need to get this thing taken care of cause my smog is almost 2 months overdue.
here is the run down...i replaced the EACV with a new one..still codes
the EACV plug consists of 2 wires on blue/yellow one black/yellow
i cut the blue/yellow and ran a direct line to ecu outside of the harness in case there was wire damaged somewhere.
no according to helms there must be a wire break between the EACV plug and the #14 Fuse under my dash...well there are so many damn wires down there i don't even know where to start..
oh and as i said the the other(possibly damaged) wire the black/yellow actually turns into a green/black where the engine harness plugs into the inside harness.
So what the hell do i do there are like 3 green/black wires around the fuse box area....is there anyway i can rig this wire to something else so it doesn't throw codes i need help quick!!!
Old Nov 21, 2003 | 05:56 AM
dingusjt's Avatar
Default Re: wiring tech help needed asap!!! (dingusjt)
please?
Old Nov 21, 2003 | 08:43 AM
kb58's Avatar
Banned
Start by checking that the correct voltages are present on the correct pins on the connector at the component in question. Do not trust the ground wire - reference your voltage measurements to the chassis of the car - because the ground wire may be the bad one. If it's all good, then pull the ECU connectors and check continuity end to end. It's like a puzzle, you have to just use the schematics as a "road map" and follow it all through. Speaking of that, the Helms manual has good directions for tracing it all out, and in what order.
Old Nov 21, 2003 | 08:48 AM
dingusjt's Avatar
Default Re: wiring tech help needed asap!!! (kb58)
man i have a voltage meter or ohmeter or whatever but i can't tell how to even use it the instructions aren't crap...
so basically it has a red wire and black wire coming from it..but there are a bunch of settings that i don't understand...but thats my problem..
but instead of dicking around i just want to replace the 2 wires cause if there is a break i have to replace it anyway..you see. so i would rather assume that both are damaged and just fix both
Old Nov 21, 2003 | 09:02 AM
PHiZ's Avatar
Don't go by color find the correct pin on the ecu connector, and trace it that way.
-PHiZ
http://www.hondaswap.com/articles/viewer.php?id=17
Old Nov 22, 2003 | 11:11 AM
dingusjt's Avatar
Default Re: wiring tech help needed asap!!! (PHiZ)
hmm thats for p28 but i already fixed the direct line to the ecu its this damn black/yellow:green/black wire that leads to the #14 fuse apparently that i need to fix.
Old Nov 22, 2003 | 03:08 PM
PHiZ's Avatar
P28/P30/p06 are all the same...
-PHiZ
Old Nov 22, 2003 | 04:14 PM
dingusjt's Avatar
yes but i have a pm5 thats for the d15b2 engine i mentioned...obd0, which a lot different than p28 etc cause i had to build a conversion harness one time and i had to change like 30+ extra wires.
Old Nov 22, 2003 | 04:31 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dingusjt &raquo;</TD></TR><TR><TD CLASS="quote">its this damn black/yellow:green/black wire that leads to the #14 fuse apparently that i need to fix.</TD></TR></TABLE>
Just run a line to battery possitive temporarily to verify that is the problem. Make sure the pins in the connector are in good shape. (making good connection)
Old Nov 22, 2003 | 05:26 PM
dingusjt's Avatar
Default Re: wiring tech help needed asap!!! (Chiovnidca)
so with the wire to positive if thats the problem then i shouldn't get an CEL?
Old Nov 22, 2003 | 05:29 PM
PHiZ's Avatar
Whups sorry, if you'd given more details, I wouldn't have made that mistake.
-PHiZ
Old Nov 22, 2003 | 05:48 PM
dingusjt's Avatar
what more details do you need?
Old Nov 22, 2003 | 07:24 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dingusjt &raquo;</TD></TR><TR><TD CLASS="quote">so with the wire to positive if thats the problem then i shouldn't get an CEL?</TD></TR></TABLE>
Right. If you still get the code, look elswhere.
EF9_TryMe
Dec 17, 2010 05:13 PM
94EGKUSH
13
Feb 3, 2009 11:55 PM
CivicVX94
10
Apr 22, 2006 11:09 AM
jbell
Apr 23, 2005 02:44 PM
EK22snatch
17
Aug 7, 2004 09:20 PM
