d15b vtec boosted with homemade setup.....need help on fuel management...
JDM D15B vtec, running 10-11psi need a chip or something to run semi normal timing, have AFC hack and 450cc injectors w/resistors
but I want to chip it, I need to have normal distributor timing otherwise I just have to retard base timing I already have it retarted 4degrees or is there another way to cure this problem....
u can try the MSD BTM ....wit tha u can set stock timing and retart to suit your driving needs
is that what u need to do ?
yeah well see i cut out at like 10-11psi and i also cant get timing back from being retarded cuz the afc hack retards it so just tryn to get it back to normal and not to cut out...is what im sayin
how much degrees ais it retarded right now?
maybe you can bootleg it and set distributor to stock and make sure all timing components are stock settings and use a light to see how much the VAFC retards it ....then what u can do is advance the distributor. this may sompensate for the retard
not sure though ....may not work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gdrum »</TD></TR><TR><TD CLASS="quote">yeah well see i cut out at like 10-11psi and i also cant get timing back from being retarded cuz the afc hack retards it so just tryn to get it back to normal and not to cut out...is what im sayin</TD></TR></TABLE>
The hack does not retard timing, it allows the ecu to advance it, and thats bad. May I suggest uberdata? I am a huge fan.
Rob
Rob
