please help: vtec doesnt always engage, temp ok and oil level ok, did a search
Old Sep 12, 2001 | 10:07 PM
MontrealR's Avatar
New User
Default please help: vtec doesnt always engage, temp ok and oil level ok, did a search
sometimes vtec doesnt kick in. is there a code for failling solenoids and if solenoids are failing, does check engine light turn on??? are they under warranty???
please reply
Old Sep 12, 2001 | 10:49 PM
Type Goch's Avatar
New User
Default Re: please help: vtec doesnt always engage, temp ok and oil level ok, did a search (MontrealR)
i think if the solenoid is not working, a CEL will definitely pop up. Are you getting a CEL?
Old Sep 12, 2001 | 11:30 PM
lotus's Avatar
New User
Default Re: please help: vtec doesnt always engage, temp ok and oil level ok, did a search (Type Goch)
Ok grasshopper... calm down and tell us all what mods you have done to your car and which was the last one...
Get my drift?
Old Sep 13, 2001 | 05:31 AM
Black R's Avatar
25 Year Member
Do you have a vtec controller? You may have a loose wire or bad unit...
Old Sep 15, 2001 | 02:13 AM
Vampyre's Avatar
Default Re: please help: vtec doesnt always engage, temp ok and oil level ok, did a search (Black R)
get an oil change my 94 wtec lude had that same problem one time vtec stoped working and i was like ahhh **** my motors dead. but i got an oil change and it work fine after that weird thing was that i only had 1500 on it since last oil change.
Old Sep 15, 2001 | 06:33 AM
Zeus's Avatar
after the car is warm, or only shortly after startup?
Old Sep 15, 2001 | 06:52 AM
FAST94GSR's Avatar
New User
Default Re: please help: vtec doesnt always engage, temp ok and oil level ok, did a search (Zeus)
more than likely its an electrical problem. verify your connections are good at the solenoid and then trace it back all the way to the ecu.
Old Sep 15, 2001 | 09:27 AM
Mai_CL-S's Avatar
New User
that happened to me a couple of times...i found it to be the car wasn't warmed up yet...... but she's fine now..
Old Sep 15, 2001 | 07:51 PM
Zeus's Avatar
Default Re: please help: vtec doesnt always engage, temp ok and oil level ok, did a search (Typ3 R Us)
...got to let'er come up to operating temp before you mash it...
em1mata
35
Dec 30, 2007 04:51 PM
FSS13foxtrot
Dec 28, 2007 12:32 AM
DC2_ITR
Apr 27, 2007 12:55 PM
VTECPowerdSi
Oct 24, 2004 04:28 PM
TodaR
Oct 3, 2002 02:11 PM
