VTEC Question HELP
Old Oct 19, 2004 | 02:08 PM
VTECPowerdSi's Avatar
Default VTEC Question HELP
I was due up for an oil change so i took my car to valvoline. after inspecting the dip stick oil was barely registering, this explained why my VTEC wasnt kicking in. i changed the oil and VTEC screamed thereafter. about 2 days after changing my oil my vtec doesnt even want to kick in now???? , what could this be? thanks h-t
Old Oct 19, 2004 | 02:12 PM
iixerOii's Avatar
Default Re: VTEC Question HELP (VTECPowerdSi)
Hmm did you check your oil level after vtec stoped working? Maybe your burning/leaking oil?
Old Oct 19, 2004 | 04:02 PM
I just checked it and its fine. i should mention however i tried using a 2001 gsr ecu and it wouldnt work, the car wuld start,crank but not turn over. could that have messed things up maybe?
Old Oct 19, 2004 | 04:49 PM
Integra_RS's Avatar
Bump b/c I would like to know
Old Oct 19, 2004 | 05:54 PM
matto2413's Avatar
i did an oil change the other day and i took my car out right after and my VTEC kicked right in. And now 2 days later the VTEC doesnt work. it might kick in once and a while. And now im throwing a check engine light for my knock sensor.Its so weird, like out of the blue. Which enables VTEC to work, but i only get the code sometimes.and even when im not getting it, VTEC still doesnt work?
Old Oct 23, 2004 | 03:20 PM
can anyone else tell me which ground wires i might need to look for or anything else that could fix this its really annoying?
Old Oct 24, 2004 | 04:28 PM
my oil pressure is at 50psi could that have something to do with it
blacktibby07
May 14, 2011 11:12 AM
tigasin
Nov 14, 2008 11:58 PM
em1mata
35
Dec 30, 2007 04:51 PM
TheAccordGuy
Dec 27, 2006 07:51 AM
fabe85
Nov 27, 2004 11:30 PM
