Guru's need: Ignition wire that goes to the ECU, is there a fuse attached at some point, how can t
Old Nov 18, 2003 | 07:59 PM
Sinner's Avatar
Default Guru's need: Ignition wire that goes to the ECU, is there a fuse attached at some point, how can t
I've installed a boxer afc along time ago, well I get a check light on the way home. it gives me map and vtec. I reset the codes and start it up, now I get just the vtec. So I swap vtec solinoids and still get it. Well it just dawned on me to check my controller. since I've never had any problems with it, i completly ignored it. Well its not turning on, I assume because its not getting power. So I grabbed a 12v light and hooked it up to the battery to make sure it worked. Then I hooked it to the ground and red "IG" wire(I assume igninition wire)from the controller. I dont get any light. Its hard for me believe that the ignition wire is out and the car is still running. Which fuse should I check for that wire? Anyone have any ideas?
Nick
Old Nov 19, 2003 | 01:33 PM
Sinner's Avatar
Default Re: Guru's need: Ignition wire that goes to the ECU, is there a fuse attached at some point, how c
bump
Old Nov 19, 2003 | 04:43 PM
Sinner's Avatar
bump
BrayzieEF9
Jan 14, 2010 10:01 AM
crx90rcr
Jul 31, 2005 08:33 AM
Sinner
Nov 19, 2003 12:01 PM
LsTurbo91
Sep 10, 2003 06:40 PM
serious
Apr 12, 2003 03:49 PM
