Ignition wire used by AFC controller. Is there a fuse on it?
Old Nov 19, 2003 | 10:24 AM
Sinner's Avatar
Default Ignition wire used by AFC controller. Is there a fuse on it?
I've installed a boxer afc along time ago, well I get a check light on the way home. it gives me map and vtec. I reset the codes and start it up, now I get just the vtec. So I swap vtec solinoids and still get it. Well it just dawned on me to check my controller. since I've never had any problems with it, i completly ignored it. Well its not turning on, I assume because its not getting power. So I grabbed a 12v light and hooked it up to the battery to make sure it worked. Then I hooked it to the ground and red "IG" wire(I assume igninition wire)from the controller. I dont get any light. Its hard for me believe that the ignition wire is out and the car is still running. Which fuse should I check for that wire? Anyone have any ideas?
Nick
Old Nov 19, 2003 | 12:01 PM
Sinner's Avatar
Default Re: Ignition wire used by AFC controller. Is there a fuse on it? (Sinner)
bump
ftrms
Dec 2, 2009 11:40 AM
t0ekn3e
Aug 31, 2004 11:00 PM
oryanh
Mar 26, 2003 02:00 PM
Vince_badaz
Feb 17, 2003 10:11 PM
