Consequences of too much oil?
Old Nov 12, 2003 | 07:24 PM
VtecDA9's Avatar
Default Consequences of too much oil?
I usually run a few cm over the second hole on the dipstick in my lsvtec just to be safe, (I theorize that i need to make up for the ss line) but are there any problems that could occur with running too much oil?
Old Nov 13, 2003 | 05:47 AM
JimBlake's Avatar
Default Re: Consequences of too much oil? (VtecDA9)
I hope you mean a few mm. A few centimeters would be a couple QUARTS high.
A couple mm shouldn't be bad.
Old Nov 13, 2003 | 06:16 AM
P1mpSlap's Avatar
TOO much will create foaming in the crankcase.
I usually run 4.5 quarts which puts me about a smidge over the second hole. I highly doubt you have anything to worry about.
Old Nov 13, 2003 | 06:22 AM
91integraLSVTEC's Avatar
but gsrs take 4.5 quarts regularly.. a b18 motor takes 4 quarts.. but yeh i fill mine to above the 2nd line almost like 2 mm..
Old Nov 13, 2003 | 06:32 AM
P1mpSlap's Avatar
It takes a LOT of oil to cause foaming in the crankcase, though. You'll either burn it off or use it.
That's why we have a crankcase baffle. So it's all good.
Delicieuxz
13
Jan 3, 2018 04:03 PM
4tika4
Feb 3, 2012 02:27 PM
StylishDOHC
May 13, 2006 07:29 AM
SlowB16
Mar 28, 2002 01:12 PM
