Oil Feed
Old Mar 26, 2002 | 10:06 PM
SlowB16's Avatar
Default Oil Feed
3 or 4 for the size. t3t4 turbine, b16. I need to order it. I think 4, but let me know.
Old Mar 26, 2002 | 10:45 PM
lucas569's Avatar
Default Re: Oil Feed (SlowB16)
pref 3 but 4 will work fine.
Old Mar 27, 2002 | 01:28 AM
SlowB16's Avatar
Default Re: Oil Feed (lucas569)
Sounds good. But, if I go with 3 do I run the risk of not getting enough oil? This is my main concern!!
Old Mar 27, 2002 | 04:55 AM
TurboSi's Avatar
What do you all mean by 3 or 4?
Old Mar 27, 2002 | 06:32 AM
b18b98's Avatar
Default Re: Oil Feed (TurboSi)
those are the sizes of the oil feed line
Old Mar 27, 2002 | 12:47 PM
Xerxes's Avatar
New User
no you'll be fine with 3. if you run 4 you'll run the risk of too much oil and going past your seals though
-Xerxes
Old Mar 27, 2002 | 01:00 PM
ArizonaTurbo's Avatar
Default Re: Oil Feed (Xerxes)
-Xerxes
Xerxes is correct! -3 AN is optimal, but -4 AN will work if that is all you have available!
Old Mar 27, 2002 | 02:07 PM
SlowB16's Avatar
Default Re: Oil Feed (TurbochargedSER)
Ill get the 3 then. Thanks again for the help!!!!
Old Mar 27, 2002 | 02:21 PM
lucas569's Avatar
where are you buying your 3an line from? are you making your own w/ earls fittings?
Old Mar 27, 2002 | 02:33 PM
HXMan's Avatar
3 is fine? Why does it seem that every kit comes with 4 then?
Old Mar 27, 2002 | 03:41 PM
You can get -3 AN lines whereever you buy any other - AN lines! I get mine from a local V8 shop here in AZ.
Old Mar 27, 2002 | 04:39 PM
HybridHatchC1's Avatar
Default Re: Oil Feed (HXMan)
true i see everyone running 4+ never seen a 3
Old Mar 27, 2002 | 05:21 PM
Smashback's Avatar
Default Re: Oil Feed (Civ-JDM)
-4 is cheaper. I have only seen -3 in Teflon and teflon fittings can cost more.
Old Mar 28, 2002 | 01:04 PM
SlowB16's Avatar
Default Re: Oil Feed (mplex2000)
I am getting it from a compressor shop. They put the fittings on in 5 minutes. The hose is teflon on the inside, steel braided on the outside. 22 dollars for 4 feet with fittings.
Old Mar 28, 2002 | 01:12 PM
Smashback's Avatar
Good deal dude!!
velisma
Jul 20, 2010 01:18 PM
Garage 808 Hatch
May 7, 2009 05:37 AM
bamboosted
May 10, 2008 01:30 PM
Ad4mGSR
Jul 23, 2004 01:15 PM
VtecDA9
Nov 13, 2003 06:32 AM
