F22 Turbo guys, still got your A/C??
I've seen on some of the F22 Turbo'd Accords that the downpipe gets in the way of the A/C lines. Any of you runnin your A/C and managed to get around this problem?
if you go with a log style manifold and keep everything conseravtive you can probably work around the ac pretty easily.
for me I would not been able to get a longer runner manifold like I wanted, nor be able to fit the 3" downpipe I wanted. too much hassle and the weather is not that bad to worry about ac.
still got A/C... the turbo kit i have is similar to greddy kit. i had to bend the a/c hardlines around a bit to make everything fit nicely.
Really?? This guy has the FMAX with the F22 and couldnt do it. Maybe cause its a CL?? Hope the link works...
http://home.insightbb.com/~niedejb/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boonacka »</TD></TR><TR><TD CLASS="quote">also looks like your wastegate flange is aimed directly at your alternator!! unless you capped that off and are using an internally wastegated turbo.</TD></TR></TABLE>
it's right above the alternator.
