Turbo manifold fitment...
hey guys,
I just got a turbo kit put together and my Revhard manifold wont newarly fit with my T3/t4e .60...which manifold is it that has the angled flange for the turbo, even if i cut the block webbing the slave cylinder is right in the opening of the compressor housing...
anyone know a manifold that has an angled flange or that sticks out a little bit further so i wont have this problem? i dont have A/C so that isnt an issue.....please help!
Re: Turbo manifold fitment... (not7fifteen)
well first which revahrd is it? There is an equal length one, a cast one and a short runner one. Also did you try flipping the turbo around so that the compressor is on the driver's side? If you dont have AC the options are pretty wide. I have a few manifolds that are not AC compatible but work quite well...
Flip it over on to the other side. That's what I did, and rotate the intake haousing if you have to. And when you flip it over to the driver side, you don't need as much piping to run to the intercooler. Which means less lag.
