wastegate spring question ( i searched for it "wastgate spring)
when im picking out a spring is for example a 7.25 psi bar, is the the least or most i can run. i forgot whhat it was. please help me out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18c1Turbo »</TD></TR><TR><TD CLASS="quote">and if you get a spring with a boost controller? how would that work?</TD></TR></TABLE>
I'd like to know too. If i got a boost controller would I need to change the springs or would i even need a spring to boost from 6-12 psi?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG(6)SR »</TD></TR><TR><TD CLASS="quote">
I'd like to know too. If i got a boost controller would I need to change the springs or would i even need a spring to boost from 6-12 psi?</TD></TR></TABLE>
The spring size will regulate your minimum boost pressure. The boost controller will be used to increase and decrease boost pressure (not lower than what's regulated by the spring).
9deuce9rr
Mar 28, 2004 12:32 PM
threatcon13
Feb 2, 2002 11:55 AM
