cant get axle in tranny..aarrrgghh
Old Oct 26, 2003 | 02:00 PM
jaxle's Avatar
Default cant get axle in tranny..aarrrgghh
so my friend and i spent the better part of this afternoon putting in a z6 tranny on my civic lx. everything is pretty much installed now except the damn driver side axle. we can not get it to pop into the tranny. is it possible a c-clip got stuck in the tranny? i just thought of that.... anyways it wont pop in. any hints on gettin better leverage to push it in or sumthing? im just so pissed off cos im so close to having my tranny swap done and a ******* axle is keeping me from being done...
Old Oct 26, 2003 | 02:17 PM
daklown's Avatar
Dat Dere Cell Tech
sledge hammer.
Old Oct 26, 2003 | 02:23 PM
quik1's Avatar
Default Re: cant get axle in tranny..aarrrgghh (jaxle)
The ring around the end of the axle might be bent and sticking out a bit you can remove that ring if you want.
Old Oct 26, 2003 | 02:34 PM
GTlvr82's Avatar
Default Re: (daklown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daklown &raquo;</TD></TR><TR><TD CLASS="quote">sledge hammer.</TD></TR></TABLE>
Or Hammer...it works!!
Old Oct 26, 2003 | 02:36 PM
pornstarSR's Avatar
Default Re: (GTlvr82)
be careful where you hit..
but yeah sometimes they can be stuborn, try putting some lube on the splines and the c clip....it might help
use some 10-w30 or some other lube
Old Oct 26, 2003 | 02:56 PM
jaxle's Avatar
c clip is fine, i actually bent it in so it would be smaller, still was being a pos. and uh... a hammer? yea where do u hit? you cant hit on the end... puts stress on the cv joints. ill try lubin it up.
and uh, u cant just remove the ring at the end, otherwise the axle will fall out.
Old Oct 26, 2003 | 03:20 PM
Newman's Avatar
New User
Default Re: (jaxle)
Does it even slide in at all? If so, then you can tap it in with a 2x4 piece of wood and a hammer (or just use a hammer if you want to) and tap it into the tranny. If it doesn't go in at all and doesn't catch, might want to make sure that you have the correct axle. On some STD sohc Civics, the axle shaft was smaller and had less splines so make sure you are using the correct axle.
Old Oct 26, 2003 | 03:30 PM
jaxle's Avatar
its the right axle, yes it slides in, splines go in fine. the passenger side went in fine.
Old Oct 26, 2003 | 03:35 PM
FMIDRC Racer's Avatar
Default Re: (jaxle)
grand the cup and slam that beast into there. if not use a rubber mallet.
Old Oct 26, 2003 | 05:12 PM
T.J.'s Avatar
Rubber mallet, just play around with it youll get it to go in.
Old Oct 26, 2003 | 07:04 PM
jaxle's Avatar
im still confused as to where i hit the axle with a hammer/rubber mallet/whatever. if you hit it on the end it wouldnt help at all, would it? the joints would just move then.
Old Oct 26, 2003 | 08:34 PM
96DX's Avatar
Default Re: (jaxle)
the driver side axle was the hardest to get into mine as well. you don't need a hammer, it'll go in... what i did was put the end of the axle just inside the tranny, grabbed the axle housing thing, get REALLY pissed and rammed that bastard in. it seems easy when you are pissed.
Old Oct 26, 2003 | 08:43 PM
racerx707's Avatar
you can tap it with a hammer just be careful not to mushroom it, I think you should just try getting physical with the bitch
Old Oct 26, 2003 | 10:46 PM
tangb2023
Guest
Posts: n/a
Default Re: (racerx707)
try turning it and wiggle at the same time.. let ur friend tap it in with a mallet..
Old Oct 27, 2003 | 04:20 AM
VRD^don's Avatar
Default Re: (pornstarSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pornstarSR &raquo;</TD></TR><TR><TD CLASS="quote">be careful where you hit..
use some 10-w30 or some other lube </TD></TR></TABLE>
this would be the way.. ..i done the same thing and the axels went in nicely..
Old Oct 28, 2003 | 06:47 AM
jaxle's Avatar
ok got it in, i used a rubber mallet to hit the inner cv joint base part, or whatever, it was erally awkward and i didnt even hit it that hard but it went in thankfuly
now i got my z6 tranny working!
Old Oct 28, 2003 | 07:07 AM
99blackcivicSi's Avatar
Default Re: (jaxle)
yeah they can be bitches sometimes but rubber mallet usally does the trick for me
Old Oct 28, 2003 | 07:26 AM
jolt-tsp's Avatar
Default Re: (99blackcivicSi)
If it's really stubborn this is what I do, works like a charm. Get a 5 or 7 ton gear puller (you don't need that much force really, just something with a large enough diameter to go around your hub assembly). put the axle through the hub, then into the tranny. pop the ball joint back in place and put the crown bolt back on (you don't need to tighten it, just do this so that it doesn't move around to much). Take the rotor off and put the gear puller on the hub so that it pushes the axle toward the transmission. Keep turning the gear puller until the axle pops into the tranny. It won't have enough clearance to leave the hub, so it has no where to go but into the tranny, so just keep cranking it until it goes in.
Momentum
Sep 2, 2010 10:06 AM
jdm_racer831
Jul 10, 2008 06:38 PM
NoVALude
Apr 28, 2006 07:54 AM
DXRiCE98
Oct 17, 2003 12:59 PM
Red_Si
Sep 23, 2003 04:03 PM
