Possible blow headgasket?
Old Oct 24, 2003 | 09:17 PM
ghettocrxsi's Avatar
Default Possible blow headgasket?
I am not sure what the problem is so I am turning to the more experienced.
When I drive my car and boost on it (sohc vtec running 6 psi) I will open the hood after a run and my coolant overflow is almost full and my hoses are firm like they are pressurized.
And this is in a 1990 crx si with stock radiator and stock cap. I am clue less. And it kinda scares me.
Old Oct 24, 2003 | 10:27 PM
spaceman's Avatar
Default Re: Possible blow headgasket? (ghettocrxsi)
are you overheating?..check out an aftermarket rad cap with a higher pressure limit
Old Oct 25, 2003 | 09:51 AM
MLogan's Avatar
When my head gasket was bad, the coolant would overflow into the reservoir tank. Check you exhaust for a fine white smoke or do a compression test. This should tell you.
squinn92
Honda Civic (2001 - 2005)
Mar 12, 2016 01:46 AM
Modern91Hatch
Jun 5, 2006 02:46 PM
Mr_Moos
Feb 13, 2006 05:59 PM
ghettocrxsi
Oct 29, 2003 02:11 PM
BoostedD15B7
Jul 28, 2002 07:14 PM
