Coolant Disappearing
Old Feb 11, 2006 | 11:09 PM
Mr_Moos's Avatar
Default Coolant Disappearing
95 hatch w/ 99 gsr swap
Coolant keeps disappearing fill it up drive for awhile then car overheats radiator is empty doesn't leak wtf where could it go ???
Air bubbles, blown headgasket?????
Old Feb 12, 2006 | 06:09 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Coolant Disappearing (Mr_Moos)
A blown head gasket will form bubbles in the coolant if that is the leak path. Are you blowing excessive white smoke from the exhaust? Does your overflow bottle leak? Is the hose leading to the overflow cracked?
Old Feb 12, 2006 | 11:56 AM
Mr_Moos's Avatar
Default Re: Coolant Disappearing (Dogginator)
Overflow is fine, Don't know bout the white smoke ill check today.. How do I check for air bubbles in the coolant???
Old Feb 12, 2006 | 12:55 PM
Dogginator's Avatar
Daisy... Daisy...
Let the car cool, open the rad cap, and start it. If it is bubbling, that is from gasses entering the system through the blown gasket.
Old Feb 12, 2006 | 02:25 PM
Mr_Moos's Avatar
ok so fill up the radiator since its empty then take off the cap and start the car?
Old Feb 12, 2006 | 02:26 PM
Dogginator's Avatar
Daisy... Daisy...
Yes.
You can also pressure test the radiator system. A compression test will also provide insight on the condition of a head gasket.
Old Feb 12, 2006 | 03:26 PM
Mr_Moos's Avatar
kk so took off the cap no bubbles car has slight white smoke not much could it be slightly blown or somthing its running right now will post again if it overheats...
Old Feb 12, 2006 | 07:19 PM
sc4dr's Avatar
headgasket could have a slight leak, also possible cracked cylinder liner, or head crack......you need to due a coolant system presure test, and most likely the head is coming off...sorry
Old Feb 12, 2006 | 07:54 PM
Mr_Moos's Avatar
Default Re: Coolant Disappearing (sc4dr)
Hmmm no problem already taken it off 4 times
How do you do a coolant pressure test any links???
Old Feb 12, 2006 | 08:36 PM
Mr_Moos's Avatar
Welp found problem Headgasket is blown
Yay get to take the head off again
Old Feb 12, 2006 | 08:50 PM
Runnerdown's Avatar
How bad did you overheat it. I never....ever see metal gaskets "blow" unless the car was really overheated bad for whatever reason. Then at that point the head is usually warped 5-10 thousandths also
Old Feb 12, 2006 | 08:51 PM
tomu06's Avatar
Default Re: Coolant Disappearing (Runnerdown)
here it is.. smokin away after a big poof of white smoke came out on the highway.. time for a new head gasket i suppose..
Old Feb 12, 2006 | 08:55 PM
tomu06's Avatar
Default Re: Coolant Disappearing (tomu06)
Different, BIGGER Pic.. enjoy.. and yes thats an intercooler.. im waiting till this biatch runs correct again to boost again..
Old Feb 12, 2006 | 09:28 PM
tomu06's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">How bad did you overheat it. I never....ever see metal gaskets "blow" unless the car was really overheated bad for whatever reason. Then at that point the head is usually warped 5-10 thousandths also </TD></TR></TABLE>
Well.. since i have gay *** indiglo's on there, the needle isnt lit up.. so when i noticed that it was on H i immediatly pulled over.. popped the hood and let it rest.. the reason its Fucked up.. is because we've use the same "Shucks" HeadGasket&lt;&lt;1st problem&gt;&gt; like 3 times.. and the 2nd time we put it on we put it on backwards so i started it up... and lost about 3 qts of oil.. i'm SURE thats not good for it.. so i am ordering a OEM one tomorrow through a hook up at Acura.. if this doesnt fix it.. im tired of this car.. and am about to sell as is.. lol.. its been like 2 Months of straight work.. mostly waiting on parts..
Old Feb 13, 2006 | 01:27 PM
tomu06's Avatar
RAWR
Old Feb 13, 2006 | 01:45 PM
hAILO's Avatar
"use the same "Shucks" HeadGasket&lt;&lt;1st problem&gt;&gt; like 3 times.. "
Old Feb 13, 2006 | 05:59 PM
sc4dr's Avatar
Default Re: Coolant Disappearing (hAILO)
uh huh
squinn92
Honda Civic (2001 - 2005)
Mar 12, 2016 01:46 AM
thewrai6th
Feb 8, 2013 02:11 PM
lil98civi
Sep 7, 2009 03:57 PM
JJexpress
Mar 25, 2009 08:28 PM
Modern91Hatch
Jun 5, 2006 02:46 PM
