does my 92-95 civic have LSD? posi track?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadow103rd »</TD></TR><TR><TD CLASS="quote">how come when i burn out there is 2 marks on each side isn't that posi</TD></TR></TABLE>
Because it just does it if you are on level ground with the same traction on both tires. It's designed to do this. That doesn't mean you have an LSD. And no Honda ever came with "posi"...
If you still think you have some sort of slip differential, try cornering around a sharp turn while placing your foot into the throttle.. you'll find out real quick what you have. An LSD will pull you around the corner, while the open differential will slip and spin the inside tire. I'm talking about hard cornering too, not ***** ****...
On another note, no LSD that has been placed inside a Honda transmission is designed to lock up both tires at any time. You'll find that even if you have an LSD, you'll still experience slip sometimes when launching. They are "drivers" LSDs.. not drag racing LSDs.
shadow103rd
Oct 24, 2003 04:52 PM
92, 95, civic, differential, differentials, honda, lsd, plymouth, posi, positrack, posy, si, track, transmission, work
