does my 92-95 civic have LSD? posi track?
Old 10-24-2003, 03:13 PM
shadow103rd's Avatar
Default does my 92-95 civic have LSD? posi track?
I was wondering beacuse I thought that only rear wheel drive cars had posi if someone could help me out with this I would be very appriciative
Old 10-24-2003, 03:22 PM
EL Vap133's Avatar
Default Re: does my 92-95 civic have LSD? posi track? (shadow103rd)
No, your stock civic does not have LSD.
Nameless RB26's Avatar
Your civic has a plain old regular open differential.
And definetely no "posi"....
Old 10-24-2003, 05:00 PM
how come when i burn out there is 2 marks on each side isn't that posi
Old 10-24-2003, 05:05 PM
EL Vap133's Avatar
Default Re: (shadow103rd)
Have one of your friends do a mean *** burnout in your car and look on both sides and see if both tires are spinning...
Old 10-24-2003, 11:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadow103rd &raquo;</TD></TR><TR><TD CLASS="quote">how come when i burn out there is 2 marks on each side isn't that posi</TD></TR></TABLE>
Because it just does it if you are on level ground with the same traction on both tires. It's designed to do this. That doesn't mean you have an LSD. And no Honda ever came with "posi"...
If you still think you have some sort of slip differential, try cornering around a sharp turn while placing your foot into the throttle.. you'll find out real quick what you have. An LSD will pull you around the corner, while the open differential will slip and spin the inside tire. I'm talking about hard cornering too, not ***** ****...
On another note, no LSD that has been placed inside a Honda transmission is designed to lock up both tires at any time. You'll find that even if you have an LSD, you'll still experience slip sometimes when launching. They are "drivers" LSDs.. not drag racing LSDs.
Old 10-24-2003, 11:57 PM
Solbros Owns Me
Evs-One's Avatar
Default Re: (Nameless EJ6)
posi=LSD.....the name GM used for it
Old 10-25-2003, 04:38 AM
Civic_95_Si's Avatar
Default Re:
"How does a posi-trac on a Plymouth work? It just DOES."
Old 10-25-2003, 07:38 AM
Carlo's Avatar
ricers, burnouts and they're way off logic.
NorthShore
08-22-2006 10:00 AM
lacking vtec
05-09-2006 11:20 AM
91crex
16
06-21-2005 03:16 AM
turbotime
07-29-2004 10:03 AM
shadow103rd
10-24-2003 04:52 PM
Quick Reply: does my 92-95 civic have LSD? posi track?
