R&R differential bearings and speedo gear (MistaBone again?)
Old Oct 24, 2003 | 07:43 AM
Wes V's Avatar
Default R&R differential bearings and speedo gear (MistaBone again?)
This question is in regards to installing a new differential (Quaife LSD).
Am I correct in the assumption that removing and replacing the noted items requires a press. (I do have access to one but just wanted to ask)
Is it possible to remove the old differential bearings and then install then on the new differential without damaging them? (My gut feeling is that it's not worth the risk.)
When installing the speedometer gear on the new differential, should it be heated in the oven first or just use a press to put it on?
Wes Vann
Old Oct 25, 2003 | 07:37 AM
Wes V's Avatar
Default Re: R&R differential bearings and speedo gear (Wes V)
bump
mach3lude
Aug 29, 2011 07:18 AM
WVTURBOCRX
Aug 25, 2007 10:13 PM
InfamousDC2FI
May 13, 2006 07:59 PM
crazy eyez killa
Dec 11, 2003 12:37 PM
jdmciviceg
Feb 2, 2002 11:25 AM
