taking out wires off the plug to ECU...
Old Oct 23, 2003 | 08:03 PM
wizzards581's Avatar
Default taking out wires off the plug to ECU...
is there any technique you guys can tel me how to move wire from the plug of the ECU... i need to move my A20 to A17...
Old Oct 23, 2003 | 08:22 PM
zelifcam's Avatar
Default Re: taking out wires off the plug to ECU... (wizzards581)
it is a bitch. try to get another connector and practice on it. the connector comes apart like two little doors on the back, then you have to unclip the actual metal pin from inside the connector. it is easier on some connectors than others. try to find a junk connector to practice on, or else you are going to end up in trouble. buy a small pick set or dental picks and probe it from both sides to unclip the pin.
-zelif
Old Oct 23, 2003 | 08:27 PM
Default Re: taking out wires off the plug to ECU... (zelifcam)
i have the jdm cut ones that came with the ecu... i can use those for practice but while im looking and pulling it... theres a technique to take it out or special tool?
Old Oct 23, 2003 | 08:40 PM
zelifcam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wizzards581 &raquo;</TD></TR><TR><TD CLASS="quote">i have the jdm cut ones that came with the ecu... i can use those for practice but while im looking and pulling it... theres a technique to take it out or special tool?</TD></TR></TABLE>
you can get a set of pick tools. sears might have them, i have no idea. they are like very thin screwdrivers with sharp points. get in the back of the connector after you have opened it's little clip doors up, and probe in there. the pin clips in using a part of the pin that is bent out at an angle. It's basically wedged in there, and you have to compress the clip and it's flare piece back together to get it out. it's hard to explain, i'm sorry. see if you can get a flashlight and see behind it or in front of it and get an idea, or, go to the grinder and cut one of your spare connectors apart so you can see what the pin assembly looks like before you start probing one that matters on your real harness.
hope this helps comrade
-zelif
Ronin150
Apr 10, 2005 05:35 PM
JDM-EJ1
Oct 10, 2004 12:17 PM
type Gendy
Feb 28, 2004 09:37 PM
