Cold Start Problems ...
Old Oct 22, 2003 | 07:18 AM
KOME's Avatar
New User
Default Cold Start Problems ...
Help ME!!!!
My civic with a JDM B18C OBD1 has a brutal time starting when the engine's cold. The engine turns over fine though it won't catch; you have to keep cranking and cranking. When it finally does catch, it shakes, sputters and dies almost immediately. You have to go through the starting process a number of times before the engine will catch and stay on, though the idling is terrible, presumably because by this time I've flooded the engine. If I give it some gas though, the revs fall dramatically and the engine could die again. It sounds as though the engine's choking. I've replaced the distributor cap and rotor, battery, plugs, and wires as well as have my mechanic take a look at my distributor coil but to no avail. I was thinking it might be my Throttle Position Sensor or maybe my MAP sensor but these are expensive parts so I'm kind of hesitant about touching these until I have a better idea.
If you have any advice or suggestions, I'll be extremely greatful if you can pass them along.
Thanks in advance.
Old Oct 22, 2003 | 07:31 AM
aw1234dude's Avatar
Default Re: Cold Start Problems ... (KOME)
Does the car idle better and not want to stall after its warmed up? It might be your IACV thats screwed up. I removed mine and cleaned the screens a while back and it solved my up and down idling problems on cold starts. Maybe you should check that out. I also heard that your FICV could cause the same problems.
Old Oct 22, 2003 | 08:59 AM
KOME's Avatar
New User
Default Re: Cold Start Problems ... (aw1234dude)
Thanks! I'll give it a try tonight. NEbody else?
Old Oct 22, 2003 | 10:21 AM
goodbyegti's Avatar
my car was a bitch to start when the ICM went but from what you're saying it doesn't sound like thats the problem, the symtoms i had were:
difficult starting
random ignition cuts with the tach dropping to zero
it ran fine until everytime the ICM went out
Old Oct 22, 2003 | 11:29 AM
AzG35's Avatar
Default Re: (goodbyegti)
Is your EVAP system hooked up? I've seen a few cars where it wasn't hooked up or incorrectly hooked up and the car idled like crap.
Old Nov 6, 2003 | 01:03 PM
SLeePeR012's Avatar
Default Re: (AzSi22)
Bump this thread right quick.
Im having a real hard time on my cold starts also.
I would sit there tryin to make the damn thing start and and when it does it sputters and chokes and sometimes dies. When I hold the gas down about 5% throttle (according to my VAFC) and I control the idle at about 2thousand it will eventually warm up and run fine.
It is NOT the IAVC for I have cleaned that about a month ago.
Old Nov 12, 2003 | 09:16 AM
KOME's Avatar
New User
Thanks for all your suggestions everybody but I'm still having issues with my starts. Any more suggestions? Looks like Mr. SLeePeR012 and I have the same problem.
Old Nov 14, 2003 | 09:42 AM
dohcnotec's Avatar
Check Fuel Pump/Fuel Filter (thats where I would have looked 1st) /Wiring
Old Mar 22, 2004 | 03:48 AM
94hondaLS's Avatar
Default Re: Cold Start Problems ... (dohcnotec)
Crap!! My car has the same problem.. And no one knows why? By the way i have a LS hatch EG
94accordlx1
Mar 25, 2019 10:24 AM
Hondalifestyle
Feb 8, 2016 10:29 PM
kingnothingftw
Mar 17, 2015 03:30 PM
AnErin
Feb 8, 2013 07:00 PM
S2k ALeN
Oct 13, 2003 01:09 PM
