Will HX rims fit 90-91 civic ex?
to make it fit, get a 5mm spacer and shave the caliper a little....
there is no way that it will clear 10.3" on EX or GSR or RS....becuase they are all the same (Nissin calipers)
so theoretically I could use a 95 civic ex caliper (non abs) and use a 5mm spacer and slight shaving to make it fit? The 90-91 ex uses the same rotors as 95 ex. The 90-91 ex calipers are the same as integra and there is no way to make those fit right? I'm asking cuz I could take my girlfriends calipers and swap them for mine. I really want to make the hx rims fit- I can't find any inexpensive 14" rims that are light.
It is easier to just find cheap 15" wheels and 15" tires. 14" is a dying size as far as tires go. 195/50 and 205/50-15s on the other hand are pretty affordable and there are tons of tires available.
The HX rims WILL fit my crx with 90-91 civic ex brakes- all I had to do was grind some of the brake pad bracket away. I borrowed a wheel from an HX today at work and checked it. I got busy with the die grinder and now all is well. I picked up some HX wheels today too. Now I'll just have to get some tires.
turbohf
10
Sep 4, 2003 09:37 PM
MyWhiteCivic
Jan 20, 2003 06:19 PM
