Will HX rims fit 90-91 civic ex?
Old 08-31-2001, 01:27 PM
fixhondas's Avatar
Default Will HX rims fit 90-91 civic ex?
Im putting ex brakes on my rex- will HX wheels fit? Caliper clearance? 10.3" rotors I believe.
Old 08-31-2001, 07:18 PM
HXMan's Avatar
Default Re: Will HX rims fit 90-91 civic ex? (fixhondas)
I know the Hx rims don't fit 5th and 6th gen Ex's....you say you are using 90-91 Ex brakes?
Old 08-31-2001, 07:22 PM
fixhondas's Avatar
Default Re: Will HX rims fit 90-91 civic ex? (HXMan)
yes with the 10.3" rotors- same size as 95 ex
Old 08-31-2001, 07:23 PM
fixhondas's Avatar
who makes some light rims in 14" that are cheap then?
Old 09-01-2001, 03:26 PM
HXMan's Avatar
Kosei makes some cheap, relativly light 15's.
Old 09-01-2001, 06:45 PM
navin's Avatar
how come HX's wont fit on 95 Civics??
Old 09-01-2001, 07:32 PM
Boba Connoisseur
SkyeC's Avatar
They only fit on 10.3" brake Civics if you grind the calipers a bit where the would hit the wheel. Peace.
Old 09-01-2001, 09:38 PM
navin's Avatar
Default Re: Will HX rims fit 90-91 civic ex? (SkyeC)
ive been told they will fit my 95 Civic ex......hmm which is right which is wrong?
Old 09-02-2001, 07:11 AM
eg6ajk's Avatar
Default Re: Will HX rims fit 90-91 civic ex? (navin)
to make it fit, get a 5mm spacer and shave the caliper a little....
there is no way that it will clear 10.3" on EX or GSR or RS....becuase they are all the same (Nissin calipers)
Old 09-02-2001, 03:55 PM
fixhondas's Avatar
Default Re: Will HX rims fit 90-91 civic ex? (eg6ajk)
so theoretically I could use a 95 civic ex caliper (non abs) and use a 5mm spacer and slight shaving to make it fit? The 90-91 ex uses the same rotors as 95 ex. The 90-91 ex calipers are the same as integra and there is no way to make those fit right? I'm asking cuz I could take my girlfriends calipers and swap them for mine. I really want to make the hx rims fit- I can't find any inexpensive 14" rims that are light.
Old 09-03-2001, 12:45 PM
Cashed EG's Avatar
I thought the 14" HX wheels would fir the civics fine.
Old 09-05-2001, 03:20 PM
Boba Connoisseur
SkyeC's Avatar
It is easier to just find cheap 15" wheels and 15" tires. 14" is a dying size as far as tires go. 195/50 and 205/50-15s on the other hand are pretty affordable and there are tons of tires available.
Old 09-10-2001, 01:55 PM
fixhondas's Avatar
The HX rims WILL fit my crx with 90-91 civic ex brakes- all I had to do was grind some of the brake pad bracket away. I borrowed a wheel from an HX today at work and checked it. I got busy with the die grinder and now all is well. I picked up some HX wheels today too. Now I'll just have to get some tires.
94civiclover
11-22-2008 02:46 AM
turbohf
10
09-04-2003 09:37 PM
MyWhiteCivic
01-20-2003 06:19 PM
M-EJ1
05-18-2002 12:18 AM
civicboi95
10-05-2001 07:04 AM
Quick Reply: Will HX rims fit 90-91 civic ex?
