overheating
Old Oct 13, 2003 | 07:18 PM
made in JAPAN's Avatar
Default overheating
car started to overheat today while at a redlight, put didnt get all the way to hot, then when i took off from the light the temp went back to normal. i popped the hood when i got home and my overflow bottle was full, and both hoses were the same temp. i think its my fan, but any other suggestions?? rad cap?? oil isnt milky and coolant is green as can be so i dont think its the head gasket.
Old Oct 13, 2003 | 07:24 PM
spaceman's Avatar
Default Re: overheating (made in JAPAN)
fan thermoswitch,thermostat,low coolant,clogged hose or radiator,water pump,leak somwhere..could be any of that..sorry i couldnt be more specific,someone else probably could give you more info
Old Oct 14, 2003 | 05:04 AM
Default Re: overheating (spaceman)
anyone else?
Old Oct 14, 2003 | 05:09 AM
pro1342's Avatar
Sounds like the fan......might be the thermoswitch.
Old Oct 14, 2003 | 07:56 AM
Rtype16's Avatar
Most likely the thermoswitch they have a tendenacy to go out.
Old Oct 14, 2003 | 08:19 AM
wickedEFguy's Avatar
to check if it's the hoses are clogged take your thermostat out and roll around for a bit to see if you temp guage rises at all. If you it doesn't then you know it's not ther thermostat. Is your fan kicking on at all? If not then hook up your fan directly to the battery to see if it's even kicking on. Sounds like either a Bad fan temp sensor or the thermostat
Old Oct 14, 2003 | 11:28 AM
Default Re: overheating (Ninja_Jc7)
update, the fan kicks on after idling for a while. and both of the hoses get warm, but the top hose gets alot warmer than the lower hose. and i took the cap off and there is tiny little black pieces floating in the coolant. the car has not overheated since this time. did the thermostat stick just once?? ive let the car idle for about 30 mins and it didnt overheat.
Old Oct 14, 2003 | 11:58 AM
1bad-eg's Avatar
I would pull that thermostat out and check it.
Old Oct 14, 2003 | 05:15 PM
pro1342's Avatar
Default Re: overheating (1bad-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bad-eg &raquo;</TD></TR><TR><TD CLASS="quote">I would pull that thermostat out and check it.</TD></TR></TABLE>
Old Oct 14, 2003 | 07:06 PM
solo2slocivic's Avatar
ditto t-stat!!!!!! did 2 today same symptoms
Old Oct 14, 2003 | 07:25 PM
Stripped Honda's Avatar
99-0104
Default Re: (solo2slocivic)
if you go through the trouble of pullint hte thermostat to look at it then just replace it at the same time .... it jusnt isnt worth taking it apart a second time
Old Oct 15, 2003 | 03:23 AM
1bad-eg's Avatar
Default Re: (Stripped Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stripped Honda &raquo;</TD></TR><TR><TD CLASS="quote">if you go through the trouble of pullint hte thermostat to look at it then just replace it at the same time .... it jusnt isnt worth taking it apart a second time
</TD></TR></TABLE>You're right on that one.
Old Oct 15, 2003 | 06:46 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
im pretty sure its the thermo switch..its just another one of those honda parts that are known to go bad (just like igniters)
Blaze45
Mar 8, 2018 02:57 PM
hotcivicsi
11
Apr 9, 2009 06:19 PM
walrus_07
Feb 21, 2009 10:16 PM
Boostn B20
48
Oct 18, 2008 08:08 PM
RTW DC2R
Apr 12, 2007 05:24 PM
