cx harness with z6?
Old Oct 13, 2003 | 12:24 PM
RabbittZ's Avatar
Default cx harness with z6?
isnt it just a plug and play situation? cant remember if the cx harness was able to do this....
Old Oct 13, 2003 | 11:38 PM
RabbittZ's Avatar
Old Oct 13, 2003 | 11:41 PM
DMoney's Avatar
Default Re: (RabbittZ)
Depending on the year of your cx, I believe 92 was the only year that CX's came pre-wired for VTEC. Correct me if I'm wrong.
- Dan
Old Oct 14, 2003 | 12:07 AM
VX's Avatar
VX
Default Re: (DMoney)
Yes ALL 1992 Civics were pre-wired for VTEC.
https://honda-tech.com/zerothread?id=645506
https://honda-tech.com/zerothread?id=643733
Old Oct 14, 2003 | 06:16 PM
RabbittZ's Avatar
thats what i though... i have a 95.... and i read somewhere how to wire up for vtec... but cant find it again.. can someone help me on that??? plus wondering also if a z6 water pump is the same as the b8?
Old Oct 14, 2003 | 06:32 PM
FMIDRC Racer's Avatar
use the search , and no it's not the same.
Old Oct 15, 2003 | 11:16 PM
RabbittZ's Avatar
did search and I couldnt find anything... but one more question...
will the dizzy work for both motors?
Old Oct 16, 2003 | 07:06 PM
d15nonvtec's Avatar
no the dizzy from the cx wont work, you have to get a z6 dizzy.
Old Oct 16, 2003 | 08:50 PM
5thgen's Avatar
Default Re: cx harness with z6? (RabbittZ)
i've got a 94 cx.....have to run 2 vtec wires. If you've got a 1-wire o2 sensor, you'll want to get a 4-wire o2 sensor with the z6 ecu. And you might have to run wires for that as well.
It'll probably be easier to get an ex/si engine bay wiring harness if you can. I had one for mine and am only having to run the 2 vtec wires to the passenger firewall.
https://honda-tech.com/zerothread?id=486353
https://honda-tech.com/zerothread?id=127778
also the cx distributor "could" work on the z6....the only thing different is the mounting holes. You will have to find a way to bolt it up to a z6 head since the holes don't match up perfect......so in other words....find a z6 dist.
Old Oct 16, 2003 | 09:30 PM
EGinNY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DMoney &raquo;</TD></TR><TR><TD CLASS="quote">Depending on the year of your cx, I believe 92 was the only year that CX's came pre-wired for VTEC. Correct me if I'm wrong.
- Dan</TD></TR></TABLE>
I got a '92 cx and put in z6 , i used the cx car harness and had to get a ex/Si engine harness and was all plug n play no mods done with p28 this luxury is only available in the '92 civic any model, '93 later needs to be wired
GRRRRRR!!!!!!! there she is
Modified by EGinNY at 1:40 AM 10/17/2003
Lamonte219
Nov 10, 2009 09:34 PM
egsleepercivic
13
May 4, 2008 10:12 PM
GTA
May 19, 2004 10:55 PM
SLowCrx
Dec 16, 2003 02:27 PM
spoonlongblock
Dec 6, 2003 03:44 PM
