cx harness with z6?
Re: (RabbittZ)
Depending on the year of your cx, I believe 92 was the only year that CX's came pre-wired for VTEC. Correct me if I'm wrong.
- Dan
- Dan
Re: (DMoney)
Yes ALL 1992 Civics were pre-wired for VTEC.
https://honda-tech.com/zerothread?id=645506
https://honda-tech.com/zerothread?id=643733
thats what i though... i have a 95.... and i read somewhere how to wire up for vtec... but cant find it again.. can someone help me on that??? plus wondering also if a z6 water pump is the same as the b8?
Re: cx harness with z6? (RabbittZ)
i've got a 94 cx.....have to run 2 vtec wires. If you've got a 1-wire o2 sensor, you'll want to get a 4-wire o2 sensor with the z6 ecu. And you might have to run wires for that as well.
It'll probably be easier to get an ex/si engine bay wiring harness if you can. I had one for mine and am only having to run the 2 vtec wires to the passenger firewall.
https://honda-tech.com/zerothread?id=486353
https://honda-tech.com/zerothread?id=127778
also the cx distributor "could" work on the z6....the only thing different is the mounting holes. You will have to find a way to bolt it up to a z6 head since the holes don't match up perfect......so in other words....find a z6 dist.
Re: (DMoney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DMoney »</TD></TR><TR><TD CLASS="quote">Depending on the year of your cx, I believe 92 was the only year that CX's came pre-wired for VTEC. Correct me if I'm wrong.
- Dan</TD></TR></TABLE>
I got a '92 cx and put in z6 , i used the cx car harness and had to get a ex/Si engine harness and was all plug n play no mods done with p28 this luxury is only available in the '92 civic any model, '93 later needs to be wired
GRRRRRR!!!!!!! there she is
Modified by EGinNY at 1:40 AM 10/17/2003
Lamonte219
11-10-2009 09:34 PM
