450cc DSM injector question (honda turbo)
Old Oct 10, 2003 | 03:03 PM
djnikko's Avatar
Default 450cc DSM injector question (honda turbo)
does everyones 450cc injectors fit flush (i.e. stock) in the stock seals? does it matter so much if there not flush? i have bored them out slightly maybe i need to do it more. has anyone else got this problem?
thanks in advance
Old Oct 10, 2003 | 03:07 PM
Hybrid Boy's Avatar
Default Re: 450cc DSM injector question (djnikko)
the rubber on the dsm injectors is larger, need to trim them
Old Oct 10, 2003 | 03:11 PM
djnikko's Avatar
Default Re: 450cc DSM injector question (Hybrid Boy)
how do you mean? trim the rubber seals? or the smaller seals on top of the injectors?
Old Oct 10, 2003 | 05:26 PM
DENCIO's Avatar
I had to bore my stock ring just a little to fit it in.. the rubber seal on the manifold.
Old Oct 10, 2003 | 08:28 PM
SOFLSOL's Avatar
Default Re: 450cc DSM injector question (mrdjay107)
Just get a dremel with a sand bit and take some off until the dsm seal fits good in the hole. Be sure to do this with the intake manifold off the car, and clean out very well. (I used a spare manifold to do this).
Old Oct 11, 2003 | 12:56 PM
djnikko's Avatar
Default Re: 450cc DSM injector question (SOFLSOL)
but do they fit flush in the stock seals?
Old Oct 11, 2003 | 01:20 PM
Mr. Softee's Avatar
mine did.
sam
Old Oct 11, 2003 | 02:14 PM
DENCIO's Avatar
Default Re: 450cc DSM injector question (94goldjungsr)
yup just like stock..
Old Oct 13, 2003 | 02:46 PM
2001teggsr's Avatar
mine fit find just put a little a$$ behind it......
Old Oct 13, 2003 | 03:00 PM
R6Elmo's Avatar
Default Re: 450cc DSM injector question (2001teggsr)
dremel out the stock seals, and yes....it should fit like stock.
Old Oct 13, 2003 | 03:45 PM
SDT Project EF's Avatar
Default Re: 450cc DSM injector question (R6Elmo)
mine fit perfectly, d16z6
Old Oct 13, 2003 | 06:58 PM
kpt4321's Avatar
You need to open the stock intake manifold seals VERY slightly, a little at a time, until the injectors fit tightly. Then, pressure test the manifold to make sure they're not leaking.
mikegeezy
Mar 5, 2007 09:10 PM
importdude2000
Apr 20, 2006 12:50 PM
Schister66
Dec 2, 2005 05:22 PM
debogsr
Sep 3, 2005 07:19 PM
4rcefeddeceiver
Jan 6, 2004 05:23 PM
