question about DSM 450cc injectors????
I just took my dsm injectors out of my eclipse because its getting donated on wednesday. I will send this injectors out to RC so they can balance and blueprint them. I doing a ls turbo setup and I want to use these injectors my question is will these injectors fit the stock fuel rail? or do I have to modify the rail to make them fit?
Re: question about DSM 450cc injectors???? (4rceFedDeceiver)
they fit the stock rail. you will need to get some new O rings that fit around the injector.
that's it
platinum.
that's it
platinum.
Re: question about DSM 450cc injectors???? (platinum00)
it's a good idea to get all new seals (upper O ring and lower seat) but I have found that the stock honda ones work fine if you hone out the middle a bit like described in about 50 other HT threads. so basicly you don't NEED to buy any seals unless they are nearing the end of their usefull life.
