DSM Injector Seals on a GSR
Hey,
Ive been searching for about a half hour and i am still unclear on how to do the seals between the injectors and the manifold.
I read a write up that new seals that are taller must be purchased and drilled out to fit the bigger injectors...
Ive also read that you just use the stock ones and drill those out.
Can somebody help me out as to exactly what seals i need to use???? EIther dimensions or car model.
Thanks alot!
Kyle
Thanks alot!
Kyle
Re: DSM Injector Seals on a GSR (EGSR)
So you just used the stock Rubber O-ring, and the stock Plastic O-ring, and drilled out the plastic one a lil bit?
Thanks for your reply.
It seems like hte injector tip would stick out about a 5mm more than stock if i did this. Is that ok?
importdude2000
04-20-2006 12:50 PM
TrueUntilDeath.com
02-21-2005 11:41 PM
