A little Spray with a built turboed B16a a bad idea????
Old Oct 10, 2003 | 04:20 AM
T-Blaze's Avatar
Default A little Spray with a built turboed B16a a bad idea????
Wassup guys?
I finally managed to get my B16A2 built after boosting a little high with a bad tune I'm currently running the Max Rev kit with stock 6.5psi spring. I'm just completing building it with Eagle Rods, JE 9:0:1 Pistons, ARP Head Studs, ARP Rod Bolts, New Bearings and all that.
I also recently bought the S200B off Doug so I have the management sorted now!!
I just wanted to know what u guys think about spraying a little Nitrous into the equation??? I know the Hondata can manage it... Also what kinda boost level would be best to tune at? looking at the flow tables my T3/T04e flows best around 16/18psi!!! Would this be the best level to tune at???
Any Help would be most appreciated!!
TIA.
Old Oct 10, 2003 | 04:32 AM
Gravy's Avatar
Default Re: A little Spray with a built turboed B16a a bad idea???? (T-Blaze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-Blaze &raquo;</TD></TR><TR><TD CLASS="quote">Wassup guys?
TIA.</TD></TR></TABLE>
yeah nitrous will feel realy nice. i would tune the car first on boost then mess with the nitrous.
Old Oct 10, 2003 | 05:31 AM
T-Blaze's Avatar
Wicked man... That's what I thought.... What kind of boost would u recommend to tune at?
Old Oct 10, 2003 | 05:43 AM
Gravy's Avatar
Default Re: (T-Blaze)
that depends on the rest of your setup. what size of injectors do you have??? and what kind of fuel are you going to tune on???
Old Oct 10, 2003 | 03:06 PM
T-Blaze's Avatar
My current injectors are 425cc but I plan on going up to some 550s very soon. It will be tuned to around 98-100ron.
Old Oct 10, 2003 | 05:37 PM
swlabhot's Avatar
Greeedy fo da needy!! WHY?? ask yourself this. You'll make plenty of power and will be more than happy with ur T3/T4. As ur not running a particularly big turbo, u ain't got that much lag to need the use of giggle gas to spool u up. It theres more bad than good putting one in as you'll have to also retune for nawz (u are planning on retuning it aren't u?? ), unless hondata has this function built in and its intelligent enough to use different maps when running with/without nawz (I doubt it somehow...). Can Hondata experts confirm this??
Lsweez
Oct 4, 2007 09:39 PM
Themouse
Jan 15, 2007 08:17 AM
RACEPAK
Aug 21, 2005 09:09 AM
MassCivicMan987
Jul 1, 2005 01:10 PM
Benjithx
Dec 11, 2004 01:31 PM
