tranny problem: shift rod floats around in gear
The car is a 95 Integra RS and in any gear the shift rod moves left and right like there is no linkage.
thanks in advance for the help.
so it doesnt shift at all?
check to make sure the roll pin is still there where the shift rod hooks up to the tranny... its the one that should have a boot around it.
Check the shift linkage. Directly behind the shift lever there's a bushing that the extension rod rides in. If it's become torn or otherwise damaged the extension rod will be allowed to move easily side to side w/o rotating the shift rod at the tranny.
shifter bushing on bottom of shifter.
The ONLY reason I went to a short shifter. Got a nice Edelbrock unit, has bearings instead of rubber O rings.
BDogggUT34
38
Apr 11, 2005 02:19 PM
SOHC_Brian
11
Nov 19, 2003 07:42 PM
